Question about Sony Cyber-Shot DSC-S70 Digital Camera
Am I having a problem with my Sony S-70
Hi, For the last 3 days, I have tried my new Sony S-70. Last night, while reviewing the photos in Photoshop, I remarked that 4 very subtil round dots of 15 pixels in diameter where present at the same exact locations on some of the 640 X 480 snapshots taken previously. To verify, I made a test by photographying a white sheet. On the neutral grey result, the dots were present at the exact same locations. I repeated the test, the same...The dots are just a little darker than the adjacent color(s). On a 100% scale I would put it, at the very most, depending of the situation, to be 1% darker. When to colors are very bright, I don't see the dots but...is this normal? I am new to digital camera but not new to photography and Photoshop. Could it be a problem with de CCD chip? Should I return the camera? I am surprised, this is such a splendid tool. Any advice will be welcomed. Fran?ois
    Master:
  • 551 Answers
Tiny dust particles on the lens can show up like this. You may not even be able to see them by looking at the lens itself. Try giving the lens a good cleaning with a Lenspen (Which you can pick up at any camera store) before taking it back. SInce the spots show up in the same locations it would argue for some fixed specs somewhere. Dead pixels usually show up as points of color instead of diffuse dark patches but a dust particle (out of focus) can do that. We know that you can see strange "flying Saucers" when there is dust in the air and you use the flash.
Posted on Sep 11, 2005
    Master:
  • 551 Answers
Francois, First make sure you ddin't buy a Nikon 990...once that's confirmed, take your S70 back! It sounds like you did all the correct tests to verify the pixels. I also did the test and my S70 passed with flying non-colors. If you 've only had it for a couple of days exchange the thing for a brand new one. Prove your point and have a photo ready of the dead pixels. good luck!
SOURCE:
No crank no start on a 02 Chevy suburban-
The no crank/no start can be due to a number of things ...
This video link reviews several reasons (relays/ignition switch/etc) ... but for the Chevy in the video it turned out to be the starter solenoid...
Chevy Truck No Start No Crank
Helpful?
Good luck on your troubleshooting
Feb 18, 2018 | Cars & Trucks
My 2 yr old Ixus 70 keps turning itself off.
How old is your battery? Keep in mind rechargeable Li-Ion batteries aren't meant to last more than a couple years, regardless of whether they've been used or not. If yours is as old as your camera, I think you know the answer. The good news is there are many inexpensive generic alternatives available these days. Some are very good, and vice versa. Research the buyer reviews before considering purchasing.
Nov 10, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hello sir, I have olympus C-70 model which is working very good for last 5 years. I am on vaction to france and it worked well till last 2 days. I have switched it off 2days back and switched on last night...
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Aug 23, 2009 | Olympus Cameras
How do I review the pictures that I have taken?
Turn the dial on top to play. Then using the arrow buttons on the back of the unit next to the screen to change between pictures.
Click on this LINK and it will take you to the Sony website which has all the instruction manuals you need to get you on your way.
Take Care,
-WN
Dec 16, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Photos on camera review but not memory card
before unplugging any usb device from the computer... it is best to safely remove before unplugging the device...
i used to just unplug before i lost over 200 pics. was able to recover using recovery software but the whole process took about 3 hours to do. since using safe remove.. not a single loss
some pros suggest formatting the card on regular basis to also clean the card of file fragments... but once card is formatted, the pics are not recoverable... be careful
Nov 15, 2008 | Olympus EVOLT E-500 Digital Camera
Ps3
Yes. That is normal. You can change that or switch it to a desktop picture (background) altogether. Update 2.2 came out last night and will enable BD-Live and better web-browsing. Good luck!! :)
Mar 25, 2008 | Sony Playstation 3 (PS3) Console
Hi Wizard
where to put the paper? There's a manual that comes with this printer, that clearly shows how to open this up, and add paper. I'd recommend you review that first. You may be thrilled when you find it
Feb 06, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
Has my F717 kicked the bucket?
If the LCD is "smeared" in record mode, it isn't the memory stick or any of the other solutions you've been offered. It's one of the following, I would guess: 1) condensation in the camera 2) loose or bad connector to the CCD or power supply 3) Camera is history. Hit eBay and get a new one BTW, It costs about $175 for repair by Sony (at least the last time I had a repair done on a 717). It's probably worth it as long as the rest of the camera is in good shape. Definitely cheaper than buying a new one or a used one. Sorry about your problem...
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-S70 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
