Hi you can use codes to unlock your mobile .you can
get the codes from here superunlockcodes here they ask the
following details before rendering the codes they are
1.mobile model
2.country from where you brought the mobile
3.provider to which the mobile is locked
4.imei number of the mobile
finally they will send you the unlock codes once
you entered the codes in your mobile as for the instructions provided by them then your mobile get
unlocked and it will accept other network sim.
SOURCE: samsung puk code to unlock for any network
You need to contact service provider to get the code .
You need to submit the IMEI number of mobile and serial number of mobile to get the puk code .
SOURCE: network lock on samsung j700
it probley means your pin numbers(puk code) so call your phone service company for one
SOURCE: trying to debrand my samsung m8800
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer caredepartment.It is free of cost.
Therestrictioncodecan be got from your old service provider..This restriction code iskeptto prevent someone who stole themobile from using it withanotherprovider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
Hope I helped
Dr Reed
SOURCE: network unlock code for samsung e1120
hi,
me too faced same problem with my Phone .....My Phone also locked it does not support Indian networks
i tried to get help from my service provider .........they couldn't help me ......... some friends suggested me to get unlock code from thirdparty which will break the network barriers ..........................
then i surfed in google and other forums and foundN-Number of sites ..................
then i went for highly recommended site in allforums ......... let me give you the link Click Here.........
Good Luck
