Question about Maytag MAV7600 Top Load Washer
I have a maytag top load washer model number MAV7757AWQ. It will not spin out ( water just sits ), until I manually move the timer to the spin cycle and restart. Is my timer bad ?
  • 706 Answers
Based on your description..the motor for the timer sounds like it is bad or one of the wires powering it came free of the motor terminal.. Does the dial spin after you start any wash setting? If not then I'd say your timer needs replacing.. Hope that helps
Posted on Aug 31, 2008
Stopped in mid cycle.
The timer went bad. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure
Nov 12, 2009 | Maytag Bravos MTW6600T Top Load Washer
Kenmore 80 series numbr CS0318980 stopped mid cycle, no power, water still in the tub... dead as a door nail. Already checked power... We also can't tell by our serial number what year we made our...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (Usually a number such as 110.######) and you'll see a list of major sub-components with diagrams and parts. You should be able to find the model number on the cabinet after lifting the lid.
If you cannot hear the motor turning at all, the problem points to one of a few places.
1. The timer. Check to see if it is moving at all.
2. The timer motor, this drives the timer.
3. The Lid Switch, If this is bad, the washer won't get into drain / spin mode.
4. The motor or capacitor themselves.
Following is the Whirlpool PDF on top load, direct drive washers with a troubleshooting section and sections on testing components.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washer Doesnt Change Cycles
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd alto look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
Sep 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 washer, does not move from one cycle to another
I'd also look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
Sep 26, 2009 | Kenmore Washing Machines
Washer will not go into spin cycle but will spin if manually move the timer to another spin cycle
timer bust new timer or new machine, try getting someone to take a look at the timer first could be dirt stopping it from turning
Jun 30, 2009 | Maytag LAT3600A Top Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag commercial washer gets to spin cycle and stops
It sounds like your timer is defective
FIX
When the machine gets to the rinse cycle slowly advance the setting to manually advance the timer
if it just sits bang on the panel or around the knob and listen if ou hear the timer start ticking you will need to replace it
Timers are avaliable from appliance parts suppliers around $29 you can get someone to install it or if you are handy can do it yourself
good luck
Nov 18, 2008 | Roper RAS6233KQ Top Load Washer
Maytag MAV7600 Top Load Washer Logo
238 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
