F20 error on vaillant eco28 combi boiler - Heating & Cooling
  • 13 Answers
F20 is a flow sensor error. Can be due to a defective sensor/ not correctly fitted, or you may have poor circulation, a big difference in flow and return temperatures, can sometimes make the boiler think it has a defective sensor, check good circulation through system, or if you have thermostatic radaiators valves on every single radiator, take 1 head off, as if you dont have a bypass fitted, it needs a radiator as a bypass circuit
Posted on Mar 03, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Checkout the co. website.!
Posted on Aug 30, 2008
    New Friend:
Check the internal rubber connection hoses on the flow and return, if they feel crunchy, that's probably your problem.
Posted on Sep 22, 2015
Hi can anybody help,i have a vaillant combi boiler and i cannot turn the heating off on the radiators can anbody help cheers!
If you they won't go off when your timer is off. There's a possibility it's clock keeping it on although its turned off, which is fairly rare. However depending in which model of Vaillant you have, if your boiler has a hot water pre-heat on it. Some models which have this the diverter was prone for sticking thus leaving the port for the radiators open when in hot water mode.
Oct 03, 2013 | Heating & Cooling
Vcw gb 242e installation manual
english -
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Vaillant/Combi%20compact%20and%20thermocompact%20logical%20fault%20finding.pdf
russian -
http://www.vaillant.ua/stepone2/data/downloads/cd/33/00/IA_VC_182E_VC_242E_Scan.pdf
Nov 11, 2012 | Computers & Internet
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Jul 14, 2017 | Water Heaters
Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Jan 23, 2010 | Heating & Cooling
Girlie - Cannot set combi boiler timer
Being the girl that you are, I'll step forward and ask your need. Can you take a phone cam pic and send it to me so I can see what the rtimer looks like. co7196@yahoo.com
Oct 06, 2009 | Desa International CBN30T Central Heating...
Vaillant combi boiler,dirty water comes out of hot and cold taps ,just been serviced by british gas,could you tell me the problem
Hi ,
Can you please tell me the model of the vaillant, and the approx age?
I can solve this problem
I await your reply
Thanks
Steve :)
Jul 16, 2009 | Water Heaters
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Dec 31, 2008 | Heating & Cooling
Heating & Cooling Logo
4,465 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
