Question about Jenn-Air Kitchen Ranges
Gas is not coming though the grill side of the stove. It sparks, makes noise, tries to work but there is no gas coming though for it to light.
  • 639 Answers
ngfam1 at your service!
if the range has sealed burners. the tops where the gas comes out the holes should lift right off without tools. The little orifice holes can be cleaned with an old tooth bush and or toothpicks to get out any food that may have dripped and gotten inside the gas escape ( orfiice ) holes!
If not it is a gas valve inside and service should be called!!
If you end up needing service, here is a good company nation wide that can make appointments 24/7!
A&E Factory service
We have been in the appliance business for 65 years!
Bless you
Please give me a good rating before you sign off !
Posted on Aug 30, 2008
3 burner - front and rear ignite,middle does not. Replaced all 3 burners. Still does not light. Suggestions?
It might be an igniter problem. It might be a problem with the gas tank (either empty or not releasing the gas). It could be a problem with the control valves or even with a safety mechanism that prevents relighting the grill after multiple tries because of a possible gas build-up. Make sure the gas tank is full and releasing gas - you should be able to hear a hissing noise in the burner compartment. If you can hear the noise then you need to check the igniter and make sure you are getting a spark, and that the spark is reaching the burner. If you can't hear a noise then either the control valves are the problem or the safety mechanism is operating. You can also call Weber and they are pretty good at helping you figure out the problem.
Jul 23, 2011 | Weber Genesis Silver A Grill
The gas jets are making a sparking noise and popping and the stove is not on
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
Sep 25, 2010 | KitchenAid KGST307 Gas Kitchen Range
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Flames from the coleman gas grill only come out from one side. the other side has worked in the past
No promise! but I had a spider make a big web in one side of mine.. could be anything
Mar 18, 2009 | Coleman Gas Grill Stove
Gas stove burner problems
Just though of something after digging through a number of manuals on various sites--with our stove, we have to open the propane valve, let it sit for a bit--to let the pressure build I guess, before trying to light it. If we don't the burner never comes fully on. Still drives my wife nuts.
Oct 27, 2008 | CADAC Grilling
Igniter "clicking" on its own...
new spark module. Most stoves use a common part.
Jul 25, 2008 | Tappan 24 in. Freestanding Gas Range...
The ignition light is a spark jumping, I assume, If so, try lighting with a match or something (be careful of the sparker) if it lights you may need to adjust the angle of the module so it catches the gas better.
Nov 30, 2007 | Stoves 1000DFDLm Gas Kitchen Range
Kitchen Ranges Logo
65 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
