Question about Home
Triton Millenium Power Shower
When we activate the power shower the water runs for five seconds, and then cuts off. The High power flow button flashes repeatedly until the unit is turned off. The shower can be restarted and this process is repeated, but the water does not continue to flow for more than five seconds.
  • juliamaxwell Aug 31, 2008
    Hi, my triton power shower does not work properly, when i turn the big knob on the front (for the power) i can hear the pump not working very well. Then after about 5 mins it just trickles...is it the pump that has packed in? Do I need a new shower or can I fix/replace the pump?
    thanx
    Julie
  • peter107 Aug 31, 2008
    the problem we have with our shower is exactly the same as jason109s, and it started on the same day !
    President:
  • 1,263 Answers
Generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Posted on Sep 03, 2008
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
My Triton Millenium shower just stopped working mid shower. Power lights went off. Have checked fuse, power ok but will not switch back on. Any ideas.
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Jan 10, 2011 | Home
Triton 300si wireless shower problem - Shower motor is working but the low presure sign is flashing but all other water pressure is normal. Water was coming out but going hot and cold but has now stopped...
check inlet water first for consistency, if flow is fine and pump is working correctly, then check non-return valve on your pump outlet.
if these check correctly, check electrical side, if flow to heating element is constant, if that is interrupted, i am afraid that motherboard on your unit may be faulty,
you have then only two choices, dismantle the unit and check all wiring and component or get unit to repair centre or call plumber... or eventually replace unit by yourself.
please be aware that mendling in electrical circuit is dangerous! fully disconnect from power before you remove the covers!!
please be aware that before you attempt to repair electrical or plumbing gear you need to cut off power or water supply to the unit in full, they do not mix very well... :-)
Jul 29, 2010 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Home Logo
611 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
