Question about Toastmaster TBR15 Bread Maker
Mixerpan leaks when licquid is added the container leaks
  • phototalks6 Aug 31, 2008
    water and dough leaks from container
  • 368 Answers
Hi phototalks6,
For Toastmaster parts, service or manuals, go to
http://prc.prodregister.com/prodprotect/applica/
And click on "toastmaster" (lower-left portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/tm.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
Where do I put the power steering fluid on a 2003 mini cooper?
No fluids are consumed on any vehicle
So why would you be adding, unless you have
a leak to repair
Have a repair shop educate you
Mar 28, 2013 | 2003 Mini Cooper
The 2000 Ford Windstar that I have is using water. I fill it up with 2 containers of antifreeze and the next evening it needs some more added. I do not see any visible leaks in the driveway or when it is...
Engine coolant that is disappearing and leaving no visible trace is NOT a good thing. You most likely have a blown head gasket or a cracked cylinder head. (engine coolant going out the exhaust) Also check your oil to make sure the water is not getting into your crankcase. If it is, the oil will be over-full and will look like a chocolate milk-shake.
Aug 03, 2011 | 2000 Ford Windstar
I am juicing oranges with ths acme juicerator and all I get is thick sluge instead of licquid juice. Can you help me I have a lot of oranges to juice.
Not really designed for juicing oranges. There is a citrus attachment but it costs too much,
better off buying a $20 citrus juicer.
Feb 19, 2011 | Acme 5001 Supreme Juicerator Juice...
Car is losing water and overheating,Where is it going? Is my water pump bad? I have to regularly add water to plastic radiator container.
if you do not see any water leaking ( dripping ) from under the car then I would say that you should start by adding antifreeze to the car and not just water -- if you are just adding water to the 'plastic container ' there is a chance that the car is just boiling off the water that is added, ( since water boils at a lower temperature then antifreeze ). if after the filling the radiator with the proper mix of antifreeze AND water you are still having a over heat issue -- then there is a chance that the thermostat or the water pump is bad and need to be replaced. could also be a cooling fan issue ( make sure the fan is turning ) --- also make sure the radiator is cooling properly. if you think that there is still a leak in the system you can have a repair shop pressure test the cooling system and they will be able to find the leak.
but again --- add antifreeze to the system and see if this helps first. you can buy antifreeze at your local auto parts store,, and since only water has been added - I would drain SOME of the fluid out of the radiator first and top off with 100% antifreeze so you have a good mixture.
I hope this helps ,, if you have further questions about this problem - please write me back here and ask and I will do my best to help.
c...
Feb 03, 2011 | 1997 Pontiac Sunfire
How do I change trans fluid on a 2008 escape hybrid
Only 2 ways that I know of....
Easiest: Suction the fluid via the dip stick tube using a drill pump (about 4 bucks at Harbor Freight or on line).
Less Easy: Remove all but one of the transmission pan bolts. With a large container under the pan, loosen the last bolt until you can pry the pan loose.... let the fluid run into the container. When it is empty, retighten that last bolt and then reinsert the removed bolts. The pan gasket should not leak when new fluid is poured into the dip stick tube (check it after about a quart is added... and snug the bolts either side of any leak).
Oct 06, 2009 | 2008 Ford Escape
I think my son hit something to cause the transmission fluid to all leak out...there is a stream from my house to where the vehicle quit and a puddle underneath...i see where to check the fluid, but not...
You will need to look under the vehicle at the transmission and verify if there is transmission case damage,a broken transmission line ect. if your son ran over something and you can see the damage then adding fluid will cause it to just leak back out of the case. You will probably need it to be towed to the mechanic if that is the case. If you try and drive it in that condition you may cause permanent damage to the vehicle's tranny. And transmission fluid is usually added in the same tube that contains the dip stick to check the level of the fluid. Also power steering fluid will also look like transmission fluid and could be a power steering leak.
Oct 03, 2009 | 2003 Suzuki Aerio
Soap does not disolve (licquid or pouches(. just
Make sure your spray arms are not clogged, large untensils/ pans hitting spray arm(s)??
Is the d/w filling with the proper amount of water?
If the above is ok, then you might have a clogged sump filter or weak main wash pump
Apr 29, 2009 | Dishwashers
Unban orkut
Try to browse orkut using proxy:
http://www.xanproxy.be/ - no ads except the first page.
http://ieproxy.com/ - no ads.
http://www.techtakeover.com/search/ - no ads.
http://www.spysurfing.com/ - no ads except front page.
http://www.myfreeproxy.be/ - ads on the front page
http://worldwideproxy.com/ - no ads.
http://www.proxytastic.com/ - contains ads.
http://www.nomorelimits.net/ - contains ads.
http://www.proxifree.com/ - contains ads.
http://browseatwork.com/ - contains ads, but clean looking
More proxy available
Dec 11, 2008 | Microsoft Internet Explorer 7
Toastmaster TBR15 Bread Maker Logo
43 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
