Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
Sportster 4 2008 Nissan Pathfinder, with proper antenna adapters for the FM modulator installed. Sirius works great but FM radio does not because there is no power to the antennas mounted in the window glass. Help!
  • 1 more comment
  • bobandr Aug 30, 2008
    The Sirius radio is off. I think the antenna connectors for the radio don't include a power source for the antennas imbedded the the rear windows.
  • Anonymous Mar 09, 2009
    you need to buy the antenna splitter for your fm radio to work static free its a pain to install but you have to unplug the antenna from your fm radio and plug it into the splitter them plug the splitter into your fm radio thats the only way i got mine to work perfectly static free
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the Sirius radio off when you are using the FM radio?
  • 2,794 Answers
Shouldn't need one. Does the rear antenna connect to the direct FM box?
Posted on Aug 30, 2008
Radio antenna
YOU NEED TO CONTACT SIRIUS CUSTOMER SUPPRT
Feb 19, 2014 | Volvo XC90 Cars & Trucks
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that...
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Jan 06, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Sep 17, 2010 | Sirius Car Audio & Video
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Connect sirius fm adapter to 2008 honda civic sedan radio
You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
This way you can switch it on any station to get rid of the static.
You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
Jun 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Install siruis sportster in 2007 murano
No need to get to the back of the radio to connect this unit as it will broadcast over an fm frequency. But if you have have issues with static, you may need to install an FM Direct Adapter which plugs into the back of your car stereo where the antenna plugs in now. Professional installation is advised, but not required. If you need more specific help, let me know.
Apr 10, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Apr 08, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
FM Modulator
I haven't found any ways that work. A better option is to use this device http://www.xm-sirius-satellite-radio.com/SIRIUS_FM_Direct_Adapter_p/fmda25.htm to make a direct connection into your radio's antenna plug. This adapter allows your satellite radio to provide clear, static-free sound. It can be difficult to install, however, depending on how hard it is to get to the back of your vehicle's radio.
Jul 13, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
214 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
