Question about Pinnacle Computers & Internet
Screen shows at quick start that pri prog was not closed correctly.Can import vidio but will not play back or make disc
  • 71 Answers
There is a corrupt file that was partially imported.
You need to flush the program cache.
Go to System Restore Point and see if you can go back to the day before this problem happened.
Now, on a separate disk backup any data you have saved just before this install point.
Restore to the old desktop state. This often solves the problem but will potentially erase all data up to that date.
Posted on Aug 30, 2008
How to unlock my sony bdps300 blue ray player
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
  • While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
  • After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control.
NOTES:If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode.
Each time this procedure is performed the disc tray will either lock or unlock.
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you.
Thanks for understanding.
Jan 19, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Dvd burner audio problem
your audio is in the wrong format when youve import ed the finished copy your software is trying to play your audio back with the original software but in the copy process another software prog has taken over and copied it in another format you will need to find out what format it was in originaly and what format its playing back in.you can probably solve this by dowloading a prog to match the format it is now trying to play back in. Understanding the problem is only half of it. now you have to find a solution.
Apr 18, 2009 | Computers & Internet
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Split Screen Same image on left & right on Screen
press the prog scan button this should fix it
Dec 12, 2007 | GoVideo R6530 DVD Recorder
DVD PLAYER PROBLEM
Sounds like a common problem with this trutech brand. There are some possibilities. 1. Laser could be worn out, 2 it could be a bad cable coming from the laser. 3 The home switch for the laser to come all the way back to its "HOME" position could be bad. But usually if this is the case, the disc won't spin at all. And 4th, the spindle motor that spins the disc could be worn out. Causing the disc not to spin fast enough and thus causing an error. Let me know if you want to send me one of these anyone so as i can trouble shoot the problem further. Keep me posted and i hope this helps you out some. Thank you Jay
Oct 10, 2007 | TruTech PVS2119 19 in. LCD Television
DVD pLayer Not spinning DVD's
if your dvd player is 5 years old or more i suggest you trash it and get a new one but if its not try to clean the lens manually with a peace of bond paper. rub the paper gently on the surface of the lens
Jul 13, 2007 | Sanyo DWM-3500 System
Computers & Internet Logo
22 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
