Question about Toshiba 55H70 55" Rear Projection Television
TP55E50 video goes out
I have a Toshiba 55 inch rear projection that has been good for 15 years, but nowit will come on and work for about 20 minutes and the screen goes black, sound is still on. I can turn it off for 15 minutes and it will come back on and be fine for another 15 minutes, It seems like something gets hot and shuts down video. Please let me know if this is something easy to fix.
  • 2,071 Answers
Trouble maybe one of the control IC there is defected or cold solder of joint of the parts causing intermittent problem. Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Hope this may help you;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Sep 06, 2008
Toshiba TP50G60 Convergence Problem ??
it was on the video output module, check bad resistor near the video output module..
let me know
Aug 07, 2008 | Toshiba TP50G60 50" Rear Projection...
My 55 inch Mitsubishi is 8 years old. when I turn it on the picture is distortedand blury. After about 20 minutes the problem goes away. Can this issue be fixed aon a set of this age or should it be...
IT MAY BE A CONVERGENCE PROBLEM, see some photos and let me know if anything like your problem.
If convergence you will see it better by going into the menu and selecting first convergence, then advanced---this will bring up a grid of lines--should be yellow with no red or blue out of place.
Good news: if this problem it can be a do it yourself repair--I have start to finish, step by step instructions for this repair in this set.
Let me know what you find and I will assist you.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 09, 2010 | Mitsubishi WS-55511 55" Rear Projection...
How do i adjust convergence on a 55 inch toshiba
You need an original working Toshiba remote: two choices here--in the customer menu there will be an option for this and there is a hidden tech menu for finer adjustment all over the screen.
Usually the customer mode works ok--if you find red or blue will not adjust somewhere you have a problem-that aside tell me what you are trying to acheive?
SD TECH
Dec 12, 2009 | Toshiba 55HX70 55" Rear Projection...
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
Jun 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I want to download tv manuel for toshiba 55 inch
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001850.pdf
You need Adobe Reader to read, but just load and click save = )
Feb 20, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Sep 26, 2008 | Toshiba 55H70 55" Rear Projection...
Convergence tp55e50
There are two Ics that need to be change to correct the convergency problem. These parts are mounted on a big heatsink.
Check this site for cheaper parts: //http://www.mcminone.com/product.asp?catalog%5Fname=MCMProducts&product%5Fid=STK392%2D110&CMP=googlepn
Jan 26, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
71 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
