Question about Intel Motherboard
Sata hd, installing windows
Help me please! I want to reinstall windows on my new Sata harddisk. I copied the NC61SXP file to floppy and insterted it when it was needed with F6. But its written that: The file txtsetup.oem could not be found. what can I do now?What´s the problem?
  • 3 more comments
  • nveronika Aug 30, 2008
    Some news: I found and downloaded file called txtsetup.oem.
    After that I could step one more in blue screen, but it writes again_: the file scsidrv.sys is corrupted.
    I really dont have idea how to continue. Thats not true that that all these files are not on the motherboard installation cd/I have motherboard Gigabyte ga-m52l-s3
    Can somebody help?
  • nveronika Aug 31, 2008
    I tried several drivers by pressing F6, but nothing.So when the setup ptompt me to press "S", i didnt do it, just continued installation. And when I had to choose where to install windows I could see my new harddisk and chose it!!!!!What is it now? It is done?
    It´s suspicious because the windows froze today morning when i switched the computer on, just at the beginning of loading it.And I couldnt do anything, I restarted it several times, always the same.Then I put windows cd in, went to repair , then it worked. Today in the afternoon the computer restarted /I dindnt touch anything/.
    Now everything is working, but I worry, I already installed a lot of programs on it, I dont want to start everything from beginning.
    What do you thing about this?
    Now this happened:After I installed a program, I restarted the computer.Everythin was loading normally, but I got a report:
    The system has recovered from a serious error.
    I really downloaded the driver ffrom manufacturer´s page, from the link you gave, but maybe I didnt choose the right one. Beacause now I tried it again and after extracting I have 2 more files then before. And I tried F6 again and it WORKED! It promt me to choose between:
    nvidia Raid Class Driver and
    nvidia nForce storage controller.
    Then I pressed F3, I didn want to contunue before I dint ask you again.
    Can I do something now without reinstalling windows?
    Thanks again!
  • nveronika Sep 01, 2008
    Thanks for your help,
    map9966!Although my computer is working well now, I will reinstall windows with setting up the sata drive - now correctly, I hope.
    Thanks again
  • 341 Answers
Is this XP or Vista? At one time SATA was new to XP and you needed a floppy with the setup instructions that came with the drive.XP has since caught up with these setup instructions.Just run setup without the floppy.Just let the floppy request time out. I can't remember the last time I had to load the floppy and I have loaded lots of Windows O.S's. If you are using RAID you should use the software that came with your board.
Posted on Nov 29, 2008
    President:
  • 2,351 Answers
Hi nveronika,
First things first. Find the name of you're SATA hard disk drive.
Please go to the manufacture's web site & download the floppy drive setup/utilities bootable software or creat a bootable CD from the manufactures site. Boot the system with their software & setup you're hard disk drive which will run in a DOS like window. (This should resovle the blue screen issue).
There are two different revision for the motherboard GA-M52l-S3
(Revisions, 2.0 uses the NVIDIA® GeForce 6100 / nForce 430 chipset): http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2818
& (Revision 1.0 which uses the NVIDIA® nForce 520LE Chipset): http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2634
Which is you're motherboard? Once you find the correct motherboard you can download the the needed software directly from the web site & create the correct floppy disk needed when pressing the F6 key during windows installation. If you still get an error message try another fresh floppy disk. (Corruption of files to a floppy usually mean the floppy drive is dirty or bad or the floppy disk is bad). It is also possible that the data cable to the floppy drive is loose or defective. Downloading directly from Gigabyte is suggested over using the CD.
Good luck nveronika!
Mike
Posted on Aug 30, 2008
  • Mike Peluso
    Mike Peluso Aug 31, 2008
    Hi nveronika, error message "System has recovered from a serious error". This is most likely generated by a software issue.
    If you did not setup your drive by using the manufacture's bootable floppy utilities software or bootable CD software it is still possible there is a FAT = File Allocation Table issue.
    A FAT issue can cause the error you saw & can continue to freeze your system, or load windows slowly. Eventually corrupting your files to the point windows will fail. (I always use the software provided by the manufacture to set up every IDE or serial ATA SATA hard disk drive when repairing a system before installing windows).
    There is an order of installing software when I work on a drive & over the years I have found this works every time. After installing windows (Fresh). Install all motherboard drivers. Register your windows by phone. Update your windows through windows update service, rebooting when windows request to. Continue to update windows up to SP2. When installing .Net framework, only install one at a time & stay in order.
    Do not install SP3. (YET). Install you're antivirus software & update it. Run a full system scan. Install programs link, java, directx 10, quick time & printer software directly from the internet. Restarting inbetween each install. Create a system restore point.
    Continue this until you have installed everything. Run you're system for a couple days as you normally would. If everything seems fine create another system restore point before installing SP3. (None of this will matter if you refuse to run the manufactures setup/utility software). If I thought this wasn't a very important thing to do I would haven't have suggested it.
    Mike
  • Mike Peluso
    Hi nveronika, you want to pick the nvidia nForce storage controller. (Do not forget to remove the floppy disk when windows finishes).
    Sorry, you must re-install windows fresh.
    I think you are a wee bit confused about setting up the new SATA hard disk drive up before installing windows. When I mention go to the manfactures site & download the bootable SATA software (I meant the "Name" of your SATA drive).
    Lets say you're new SATA drive is a Seagate drive. I suggest you go to Seagates web site & read how to download & create a bootable floppy disk so you can format your SATA drive. Read through this Seagate link;
    http://www.seagate.com/ww/v/index.jsp?lo...
    DiscWizard Starter Edition diskette. (Two floppy disks needed).
    This is what I mean when I say go to the manfactures web site. Every SATA & IDE hard disk drive manufacture allows you to download & create bootable floppy software to setup your new SATA drive. The bootable software also allows you to turn on & off other drive features that windows can not do.
3 Suggested Answers
colliewob
  • 781 Answers
SOURCE: not able to install windows
You need to sliptream SATA drivers into your setup disk.
Download from here
http://driverpacks.net/DriverPacks/
driverpacks mass storage
copy windows CD to hard drive then use "Nlite" to insert them into the drivers section
then burn to a new CD.
and reboot from it should have no problem then
Posted on Dec 10, 2008
  • 1027 Answers
SOURCE: How to create floppy with SATA drivers (NO mobo CD)
Don't need to use a floppy - copy the files to a USB Flash drive, and when the Windows asks for the source, select the drive.
Posted on Apr 22, 2010
Computer won't boot error code sata disk s/n 0F00-136B and many more???
looks like hardware failure.
find out what harddisk exactly you do have in the bios :
- press Del or F1 or F2 during booting, goto IDE devices, look for the model, size (in GB) etc.,
write down (the manufacturer could be: samsung, seagate, maxtor, fujitsu...)
- then change order of boot devices so that cd/dvd-rom drive and /or 3,5 '' floppy drive boots
before the harddisk, exit saving changes (F10 or Esc)
- then get diagnosis program from the harddisk manufacturer's homepage,
copy that to a bootable floppy disk or burn it to a cd-r/cd-rw which must be bootable
- boot from the cd or floppy, run diagnosis tool, both short and long test, what does it say then?
- if hardformat is available, perform one
- might work now, at least the hd will be recognized
-setup new windows installation.
have fun
Source : STAT DISK S/N 0F00-136B
Aug 16, 2012 | Dell Computers & Internet
Sata driver for Samsung harddisk
You need driver SATA controller that is used on your motherboard. You need to find CD or download from internet, drivers for your SATA controller that is used by your motherboard. Put this *.inf files on bootable Floppy diskette. In Windows XP setup press F6, when it askes you. If you found correct driver you will see your HDD in setup.
Apr 16, 2010 | Computers & Internet
WATS THE PROCEDURE OF INSTALLED SATA DRIVER ON P5RD1-VM?
put the one end SATA cable to the HD and other end to motherboard then connect the sata power cable to the hd as well.
Sep 15, 2009 | ASUS P5RD1-VM Motherboard
I want to reinstall my Y computer but the restore CD does not seem to work. So i tried a new XP cd, but that too could not work as it does not see the SATA hard disk installed. The Bios on the Tecra M9...
Hi, your Windows XP install CD doesn't have SATA drivers for the hard drive included, so it's not able to address your hard drive. You can't disable SATA in the BIOS to make it work since your hard drive is still SATA. You'll need to get a 3.5" floppy disk and drive if your laptop doesn't have one. They make external 3.5" USB floppy drives that will work.
1. download the SATA drivers for your laptop (iastor.sys and inf)
2. copy the drivers to your floppy disk (about 6-7 files)
3. plug the floppy drive into your laptop
4. boot to the Windows XP CD
5. as soon as the installation starts, it asks you to "Press F6 to specify RAID or controller drivers" - Press F6 now
6. When setup asks for it, point it to the floppy drive
7. Installation will continue and find your SATA hard drive
Ta-da! Rock on with your bad self.
May 18, 2009 | Toshiba Tecra M9-S5517X PC Notebook
Acer 3050 won't boot. Disk Read Error
have fun
Apr 21, 2009 | Computers & Internet
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Can't install Hard Drive MS Server 2003
HI.. please specify the ASRock motherboard model, check whether it is using which chipset as SATA Controller... ICH6 or ICH7 or ICH8 or ICH9
ICH5/6 Sata Raid drivers
http://down3.driversdown.com/Bios/ich5r_6300esb_ich6r_msft_raid.exe
ICH6/7/8 Sata Raid drivers
http://down3.driversdown.com/Mainboard/iata621_cd.exe
ICH9
http://downloadmirror.intel.com/14849/eng/f6flpy32.zip
Please tell me if u need anything else.....
Regards,
Siddesh Prabhu
Aug 30, 2008 | Intel Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
try running scandisk on the floppy disc to fix errors with the txtsetup.oem file.
Aug 16, 2007 | Asrock K8 Combo-Z Motherboard
Intel Motherboard Logo
1,084 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
