Question about Toshiba 52HM95 52" HDTV Projection Television
Noise from the back
My 52 " dlp toshiba makes steady noise from the back and even when I shut the tv off
  • yogiberra Jan 08, 2009
    I have the same problem. I bought the Toshiba DLP 52" tv more than a year ago and just recently it started making a humming noise from the rear side. The noise stays even when th tv is off. Is anything can be done to fix the problem?
    Problem Solver:
  • 4 Answers
Its your light engine going out and it will cost you anywhere from $700 to $1000 to fix it. Save the lamp and find a cliff to push it over when it goes. There really ought to be a class action suite against Toshiba for selling such an piece of ****.
Posted on Sep 22, 2008
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
I have a Toshiba 50HM66 DLP TV. I turn it on and after a minute or two the screen goes black but the volume is still present most of the time. The picture may come back a few minutes later but go again.The...
I hope our expert would have provided you helpful info in chat session, if you still need further help, let me know the steps taken so far to solve the problem of your tv.
Thanks.
Sep 18, 2010 | Toshiba 50HM66 52" Television
I have a toshiba 62HM95 DLR TV. I was advised by Toshiba that I needed to replace the lamp to correct my issue. However the replacement lamp worked for 1 evening and I am now back to my original issue. ...
This could be a sign of the color wheel failing. This is part of the light engine assembly and is not sold separately as far as I know. My most common source lists the light engine as out of stock. (The last quote I had was ~$600 for the assembly.)
The cooling fans can also cause a noise as they fail. However, the red light would be blinking in that case.
I hope this helps.
Sep 01, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Humming fan
ok it could be a fan...or a colorwheel...turn the tv on....let it power all the way up...then shut down ...you are listening for WHEN the noise stops...does it stop when the lamp powers down..look @ the back to see this..if it does then it will need a colorwheel..if the noise is there for 5-10 minutes after lamp has shutdown then it is a fan...problem: there are 3-4 fans in the tv...which one is the next question...let me know what you find..
Sep 09, 2008 | Televison & Video
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Toshiba 52HM95 52" HDTV Projection Television Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
