Question about Intel Motherboard
Can't install Hard Drive MS Server 2003
I recently purchased a new 250 GB WD SATA HD, and I am trying to install it on my Combo Z. The support disk that came with the board was stolen from me so I downloaded all the support files from ASRock's site. I created the floppy for use to install SATA RAID drives with XP. I load the CD and boot from it and press F6 so that I can choose to use the RAID drivers provided by ASROCK (Windows is unable to see the HD if I do not provide the driver manually). When the installation asks for the driver, I put in the floppy with the drivers. I then get an error telling me that the first line in the txtsetup.oem file is invalid. I have been fighting this thing for a week. I have another WD SATA 80 GB drive as well. I cannot seem to get either to be seen. HELP PLEASE! Help me please! I want to install windows on my new Sata harddisk. I copied the NC61SXP file to floppy and insterted it when it was needed with F6. But its written that: The file txtsetup.oem could not be found. what can I do now?
HI.. please specify the ASRock motherboard model, check whether it is using which chipset as SATA Controller... ICH6 or ICH7 or ICH8 or ICH9
ICH5/6 Sata Raid drivers
http://down3.driversdown.com/Bios/ich5r_6300esb_ich6r_msft_raid.exe
ICH6/7/8 Sata Raid drivers
http://down3.driversdown.com/Mainboard/iata621_cd.exe
ICH9
http://downloadmirror.intel.com/14849/eng/f6flpy32.zip
Please tell me if u need anything else.....
Regards,
Siddesh Prabhu
Posted on Sep 28, 2008
  • 1 more comment
  • TechGuyLive Sep 28, 2008
    Please rate my answer.... :)
    follow the same procedure , load the CD and boot from it and press F6 so that I can choose to use the appropriate RAID drivers provided according to the ICH chipset your motherboard is having. and select the SATA AHCI ICH6,7,8 ot 9 driver...
    If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
    AHCI is the acronym for the Advanced Host Controller Interface. It is a new interface specification that allows the SATA controller driver to support advanced features
    When disabled, the SATA controller disables its AHCI functions when the computer boots up.
    When enabled, the SATA controller enables its AHCI features when the computer boots up
2 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Sata hd, installing windows
Hi nveronika,
First things first. Find the name of you're SATA hard disk drive.
Please go to the manufacture's web site & download the floppy drive setup/utilities bootable software or creat a bootable CD from the manufactures site. Boot the system with their software & setup you're hard disk drive which will run in a DOS like window. (This should resovle the blue screen issue).
There are two different revision for the motherboard GA-M52l-S3
(Revisions, 2.0 uses the NVIDIA® GeForce 6100 / nForce 430 chipset): http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2818
& (Revision 1.0 which uses the NVIDIA® nForce 520LE Chipset): http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2634
Which is you're motherboard? Once you find the correct motherboard you can download the the needed software directly from the web site & create the correct floppy disk needed when pressing the F6 key during windows installation. If you still get an error message try another fresh floppy disk. (Corruption of files to a floppy usually mean the floppy drive is dirty or bad or the floppy disk is bad). It is also possible that the data cable to the floppy drive is loose or defective. Downloading directly from Gigabyte is suggested over using the CD.
Good luck nveronika!
Mike
Posted on Aug 30, 2008
Cannot open
1 of 2 possible problems. You have a bad USB cord or the controller card wentt out in the external drive. If cord works w/another peice of hardware, then it's controller card. To test if HD is bad, remove it from the case and connect it to your pc via SATA cable to mother board and use power from pc power supply. If you can access the HD here, just purchase a new external closure.Don't spend a lot of money, they're relitively inexpensive. If you don't have the necessary cabling, you might need to visit a local reair shop or friend that has the ability and cabling. Most all pc repair shops will check the HD out to see if its works and also carry the external HD cases.
Dec 01, 2010 | Western Digital WD Passport 250GB Portable...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
SOYO KT600 Dragon Plus mobo not recognize WD Caviar SATA 1TB HDD
Yuck! Soyo filed for bankruptcy in May and their website is gone!
You need to enable the SATA in the rom bios AND install the drivers for it; but, I hope you have the manual and the CD.
Jul 05, 2009 | Soyo Computers & Internet
HI i m posting the same problem onceagain with the trouble shooti
You could try flashing to the latest bios and disabling SATA RAID, disabling IDEs including bus master if u dont use any.
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Sata hd
Previously we had IDE hard disk due to some problem hard disk was dead. We purchased SATA 250 GB hard disk, we connected and we tried so many times but is not working. Its says setup did not find any hard disk. Kindly help us
Apr 03, 2009 | Computers & Internet
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
Jan 12, 2009 | Western Digital WD2500JS 250GB SATA2...
D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Oct 16, 2008 | Intel D845GLLY Motherboard
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
try running scandisk on the floppy disc to fix errors with the txtsetup.oem file.
Aug 16, 2007 | Asrock K8 Combo-Z Motherboard
Intel Motherboard Logo
855 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
