Question about Palm Zire 72 Handheld
Fatal Exception every time I sync.
I upgraded to a Zire 72 from the 505 and now as I am trying to sync, I get a fatal error every time which requires a hard reset. Any suggestions?
    Master:
  • 473 Answers
Forgot to add that - after you copied the back-up directory to a safe place - you need to delete it to avoid ending up with the original configuration after a first hotsync! BTW - did you simply hotsync using the configuration you used with the m505? Some m505 applications may not work properly on newer units and cause fatal errors.
Posted on Sep 11, 2005
    Master:
  • 473 Answers
Check docs to go and Avantgo Documents to Go and Avantgo are usually the culprit with me; if you use these try to reinstall. Check (delete and reinstall) "complex" applications, build to be able to use databases on the SD card. The final straw is the procedure suggested by Palm; -make a copy of your back-up from the palm directory; program files/palmone/van/backup. - do a hard reset - reinstall the applications one by one, hotsync after every install until you have found the offending application
Fatal application error,program:mobilenavigator.exe,exception:0xC0000005,Dress:00D36448
PROGRAM: R66N8.EXE Exception:0xC0000005
Address:00099dDB4
FATAL APPLICATION ERROR
Jan 07, 2012 | GPS
What is causing igi starting error?
There are so many reasons why the fatal exception error has occurred. First, your video card maybe has below specs and need to upgrade. Second, maybe you didn't install a direct x in your computer that's why games didn't run successfully. Last, some files are corrupt so the game will not run properly. Solutions:
First, upgrade your video card to a higher spec.
Second, try to install a direct x in your computer. This is the link to download DirectX
Third, try to uninstall the game and reinstall it again.
Aug 17, 2011 | Computers & Internet
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
Need answer for fatal error
Look for the reset button. And then reset. And as it does not help connect to your computer and upgrade software
Nov 30, 2009 | Nextar X3-03 Car GPS Receiver
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
Fatal exception error
Those are just messages about the stream sockets closing without the protocol closing the connection cleanly. What that means is that the Data network is not configured correctly, I assume somebody made a change or upgraded a network switch and didn't configure it correctly.
Oct 26, 2008 | Mitel 5220 IP Phone
Fatal exception
Sounds like a third-party app is causing the problem.
Try Palm's own guide to diagnosis and you should find out what.
Palm page
Regards
Philip
Jun 14, 2008 | Palm Zire 72 Handheld
Emachine will not start up it says fatal error regeristery not updated, then turns off
Linux and UNIX ld command help -z defs, Force a fatal error if any undefined symbols remain at the end of the ... which are marked lazyload will not be loaded at initial process startup
E-mail CHID: 5369 Unfortunately we were unable to find anything about the Fatal Exception error message you are encountering we suggest you go through the basic fatal.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | E-Machines eMachines Desktop PC
hold down the up button and use a paper clip or tip of your stylis to reset, do both of these at the same time.
Aug 08, 2006 | Palm Zire 72 Handheld
Palm Zire 72 Handheld Logo
144 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
