Question about Palm Zire 72 Handheld
Error Message - "Unsupported Repeat Pattern"
I have a recurring appointment setup in Outlook 2003 with a repeat pattern of "first weekday of every month". When I synch to my Zire72, the following shows up in the HotSynch Log: "The repeating appointment titled Run Financial Reports beginning 04/01/2005 07:00:00 AM cannot be converted for use on the Handheld. Please edit the appointment in Outlook and re-synchronize (unsupported repeat pattern)." ==================== I understand the error message, but am at a lost to comprehend why such a simple repeat pattern is _not_ supported. Anyone know of any workarounds?
    Master:
  • 473 Answers
I think the message means what it says. You will have to setup these events manually as individuals to get this event to synch. The message is literally telling you that this repitition style is supported by Outlook but not by the Calendar in your handheld. Another way to go might be to use Chapura PocketMirror conduits instead. It may be more forgiving and be able to deal with this event type. This will cost you however to find out.
Posted on Sep 11, 2005
Forget my pattern
  1. Enter wrong pattern 5 times.
  2. In incorrect password message will be displayed, Tap OK.
  3. Tap Forgot Pattern?
  4. Enter your Gmail Username and Password account details that were used when setting up the phone.
  5. Tap Sign In.
  6. The phone will prompt you to draw a new Pattern Lock. Draw the Pattern and tap Continue.
  7. Repeat the Pattern and tap Confirm.
Apr 17, 2014 | Sony Ericsson XPERIA X10 Cell Phone
I am knitting a hat that is smaller than the instructions call for . How do I determine the amount of repeat stiches between the decreases for the crown
you could just use a smaller needle and use the pattern as is..to determine the repeats,look at the the pattern and see how many repeats they have in it.decrease one st per repeat all the around..
Feb 08, 2014 | Sewing Machines
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
LG KP500 Cookie bugs - Calendar Alarms and Sync
I have a lot of problems with the calender. when I first got the phone, a week or two ago, I put my work houres in it, and the whole week, no alarm. then weekend came and a small icon above of a small calender appeared, and the whole weekend it kept on going off 5 times in a row at 7.30, the time I needed to leave for work in the week, when it didnt went off at all O_o today, I had to leave at 8.30 and it went off at 8.30 but also at 7.30 again, while that's not an alarm in my calendar for today.. after work my cookie suddenly went out, I had to take the battery pack out to "reboot" it, now the calender icon is gone, I wonder if it will go off at 8.30 tomorow like planned or if it won't go off at all anymore again..
Another thing I noticed is, that when I put in a date from one houre to another is that it doesn't state the correct houre (when I put in 8.00 to 16.00 it shows 00.00 to 16.00) I put in until I open the actual appointement.
strangely enough, my cookie just lighted up it's screen as if I touched it out of itself and even more strange, the calendar icon up there is back..!
Mar 06, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
I wouldnt recomend this phone at all! Have had it 4 months now and had so many probs including:
1. Sometimes the alarm comes up but doesnt make a sound or vibrate so obviously i sleep right through it
2. It will randomly turn itself off
3. At least once a day when someone texts me ill get the same text two or three times. I'd blame their phones but its not just one person!
4. It randomly was diverting all my calls at one point although id never set it to do that.
5. The sensors dont work right. WHen you go on the internet if you turn the phone to one side the screen also turns. Ill be holding mine the right way up but the screen will still turn, it needs a lot of shaking to correct itself.
6. I cant move anything about on my screen. I had a few speed dials up but got sick of accidentally ringing them, they wont move anywhere on my screen so i cant put them away. However it lets me drag other speed dials onto the screen (but not back again so my screen is packed with speed dial boxes!)
Do not buy this phone!!
Nov 27, 2008 | Lands Phones
When synching new Outlook calendar items, a "note" is added to the T5 calendar item
I have the same problem. T5 Win XP Home HP Pavilion Desktop Outlook 2003. It seems to only attach the blank notes to recurring appointments. Delete them all (which is annoying) and they come back after a HotSync
Sep 11, 2005 | Palm Tungsten T5 - Multilingual Handheld
Outlook Meeting Requests Changing
similar problem with my Palm Vx syncing with Outlook 2003 My recurring meetings lose attendees and other attributes like labels when I make a change to a specific date in the recurring series. If I leave the original recurring event untouched the problem does not occur
Sep 11, 2005 | Palm Tungsten T3 Handheld
Palm Zire 72 Handheld Logo
125 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
