Problem with sound system
In the sound devices,i had two devices:speaker and realtek digital output.By mistake i disabled the sound device(i didn't uninstall it).Now,i am not able to find the speaker icon anywhere and the sound players are displayig everything properly but i get no sound in any of the players. i have acer aspire 4720 model and dolby digital live speakers
    Master:
  • 763 Answers
Try to look on the control panel of your computer and find the sound effect manage or sound and audio devices. if still doesn't work then try to reinstall again your audio driver from your motherboard driver cd. it will solve the problem.
cheers
CHARCOIS
Posted on Aug 30, 2008
How do I fix my realtek speakers? They play sounds and music but while doing so the sound icon in the taskbar is showing movement from bottom to top with sound increasing as it goes upwards?
Open Device manager and right click on "Realtek HD Audio"
Select 'enable'
Right click on the speaker icon in the taskbar and select 'Playback devices' ensure that Realtek is checked as the default speaker device
Right click alongside the speaker icon and make sure they are not disabled
Use the 'Test' facility to check the audio
You may have to update the driver as well
Jun 25, 2015 | Realtek Semiconductor Realtek High...
3rd USB Port doesn't work and "no audio output device is installed" in Vista 32-bit
The USB port is damaged, or missing the driver for that port, check device manager.
Mar 15, 2012 | Computers & Internet
No Audio Output Device is Installed written in speaker marked with cross
Sounds like you just need to install a driver for the sound card.You didn't mention your Operating System so I will give you this LINK and all you have to do is pick your operating system and then drivers and choose the latest audio driver.
Jun 15, 2011 | Intel D845GVSR Motherboard
No sound
Go into your sounds settings Control Panel> Hardware and Sound (on Xp its just sound)> sound> You should have 4 types of speakers available. I have Digital Output Device (HDMI) Speakers Realtek Digital Output Realtek HDMIOutput my default was the HDMI and i changed it to speakers and then my speakers worked.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 26, 2010 | E-Machines T3504 PC Desktop
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
No audio on pc problem
Check the Sound and Audio settings to make sure that the proper output device has been selected. Go to your Control Panel then Sound and Audio Devices, then the Audio tab. In that tab make sure that Default Sound Playback is set your sound card.
Sep 25, 2009 | Computers & Internet
Bose Companion 3 and Realtek HD Audio Card - No sound
Hi: I'm sure you checked the volume control of the Bose controller. Check where you plugged it in to the back of your computer. Mine has a veriable outpup and a fixed output. I hope this helps, Jeff
May 31, 2009 | Dell Computers & Internet
i think your spund drivers are not updated as per your requirement and they are not working properly....
secondally it might b a problem in your volume controler or audio pin
Feb 22, 2009 | Creative Labs Computers & Internet
NO SOUND OUTPUT
Check if the correct device is set for default output
Click Start
Control Panel
Sound
Select the correct speakers and set as default (like described as Realtek High definition Audio)
if you double click them, you can also change some settings there, I recommend you disable enhancements.
Finally, with the realtek driver comes a little application that runs in your tray (usually and orange speaker) verify settings there as well
Good luck, hope this helps
Feb 03, 2009 | Microsoft Windows Vista Ultimate Edition
No Sound
ATI is the graphics card developer. Your motherboard has onboard audio that appears to be Realtek. You should not have an ATI sound driver... as they don't exist.
I'm assuming you're using WinXP to make thing simple. If you're using Vista, try to do the equivalent.
Since your graphics card is capable of HDMI, the problem could be that the card expects to output audio through your graphics card rather than the sound card. Check start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings -- go to the Audio tab and make sure it says Realtek for output. If it shows more than one output device, set it to realtek. If it doesn't show realtek, follow the below instructions, and then double check at the end that the Output device is set to Realtek.
1>Please go to HP's site and download their Audio drivers.
2>Go to Device manager -> Sound, Video, and game controllers.
2.1> Does it have an entry saying "Realtek blah blah Audio" there? If not, what entries does it have for audio? Ignore Audio Codecs and Legacy Audio Drivers.
2.2>If there's nothing there, you need to install the drivers you downloaded. If there is something there, please continue to #3.
2.3>After installing the driver, restart computer.
2.4>Once computer is restarted, go start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings. Hit the button labeled Advanced and adjust the speaker setup to whatever you have - surround sound, 5.1, quad, stereo, whatever.
2.5> Go to #5
3> If there is anything that says Realtek/Azalia Audi, right click it and Uninstall.
3.1> Restart computer.
4>Install audio driver you downloaded, and perform #2.4.
5>Find the driver icon (there's probably on in the task tray) or find it under start -> Control Panel -> Sounds and audio. Set your speaker settings there as well. Audio I/O should specify what ports go to what speakers What you set in windows should match the Realtek audio manager's speaker setup.
If problem persists, please report this.
Dec 14, 2008 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
