Question about OKI Office Equipment & Supplies
I just replaced the toner cartridges for the second time but still find my print (text) is grey instead of black and looks like it is suffering from double vision (or I am suffering from double vision) but the print looks like there are two letters, each slightly off from each other
    President:
  • 2,072 Answers
1 of two things. You have a bad heat roll in the fuser. They will wear out the teflon and cause that problem. That is the very hot area in the exit area of the machine.
Also there s a machine made by Sharp but marketed by 3 or 4 vendors, Sharp, Toshiba, Xerox and some others, where the high voltage power supply will cause that problem.
Most likely the fuser needs replaced. That is the most likely problem. I mention the high voltage power supply because it is a possibility.
Posted on Aug 30, 2008
Why is my printer printing very faded grey text instead of black?
getting low on black toner? When you changed the black toner, did you remember to remove the plastic strip? Silly question, I know, but it happens.
Jul 17, 2014 | Dell 5100cn Laser Printer
My Dell 1320c Colour Laser Printer prints black as grey. How can I get it to print black?
If you have an extra black toner cartridge, try installing that and see if it fixes the problem. If it doesn't make sure Toner Save Mode is off (in the print driver, under Preferences). If your copies still come out gray instead of black, you may need to replace the Print Head Unit (PHD).
Feb 21, 2011 | Dell 1320c Laser Printer
Dell 3110cn - getting grey tint and wavy lines
It sounds like you have leaky toner or the imaging drum needs to be replaced.
Feb 17, 2010 | Dell 3110cn Laser Printer
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hi when printing black or grey outside edges
sounds like your black toner cartridge is getting low or not filled evenly. To fix this until it get a bit lower on toner just take the cartridge out and holding it up right give it a few shakes side to side. The will spread the toner power out inside and you should be printing normally again.
This can also happen if you moved or bumped the printer. Usually you only see this when the toner is low or after you print a lot of pages. Most text is in the mid of the paper so thats where the toner get s used the most.
Oct 23, 2009 | Samsung CLP-350N Laser Printer
My watermarks are printing as pink instead of gray, this started happening after I changed the black cartridge. I have not made changes to the original document, and normal text still prints as black
if that is a refilled cartridge, you might have a problem with the ink. try print something (text) in pure black , and grey only, and see waht happens, if does notprint, means the printer has hard time with that black cartridge.
Jun 17, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
OKI c5100 Printing GREY instead of BLACK.
Not able to print a status page. Tried holding down menu 5 sec and no output. I searched the menu and am not able to find how to print status page. I did print out a demo page and the black is great but when i print out text (like the entire menu map) the black is grey. Let me know if there is anything else I can do.
Jan 12, 2008 | OKI C5100n Laser Printer
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
105 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
