Software Installation problem gets stuck - all in one Kodak ESP3 printer
We cannot complete the installation of the disk or downloading software from the website it gets stuck half way through. We have a Vista computer. Please help
  • Anonymous Nov 24, 2008
    Hi!
    I've the same problem. When I install the software it stop after a short time. It says, that the KODAK All-in-one software can not follow my instructions. (error code 1935x17x2951053040x). I hope, somebody have an idear what I can do or if the function of the ESP3 is like the function of another Printer, e.g. some of Epson.
    Thank you!!
    P.S.: I'm sorry, I'm from Germany and my English isn't very great!
  • Iso Gomez
    Iso Gomez Nov 23, 2013
    I want to instal all- in one printer please help
I have a 6 year old Dell with XP, plenty of hard drive and memory. I could not scan using the software, I went on the Kodak website and followed the Step-by-Step Solutions and Repair which nothing worked, including the Kodak Clear Utility they reccomend for ridding your system of the software, it just locked up at the end.
So, I spent several hours on the phone with Technicians trying to uninstall and reinstall the ESP3 software. None of their methods worked even step by step manually un-installing every file and folder...
So I wrote a nasty email to them and they sent this back, which by the way, didn't work for me either, but maybe it can for you.
According to your email, the issue is that you have not been able to install the software for the printer on your computer. We understand the importance for you to have your printer working properly.
To help resolve this issue, please follow these steps in the order they appear:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the Kodak EasyShare 5000 series all-in-one software:
a. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
b. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
Kodak EasyShare software
Kodak all-in-one printer software
c. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
d. When the Install Wizard appears, click Next.
e. Depending on the issue(s) you are experiencing, do the following:
If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
g. In the Ready to remove the program window, click Next.
h. In the Uninstall Complete window, click Continue.
i. Restart the computer.
3. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
a. Printer folder in C:\Program Files\Kodak
b. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
c. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
d. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
b. Eastman Kodak Company folder in C:\ProgramData
c. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
4. Run Disk Cleanup.
a. Open My Computer.
b. Right-click Local Disk (C:) and select Properties.
c. Click the Disk Cleanup button.
d. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
e. Click OK, and then click Yes to delete all files and begin the Disk Cleanup.
f. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
5. Shut down all background applications.
a. Select Start > Run.
b. Type msconfig in the Open field, and click OK.
c. Select the Startup tab.
IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
d. Click Disable All , then click OK .
e. When prompted, restart the computer.
6. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
a. Insert the printer software CD into the CD-ROM drive.
b. In the KODAK EASYSHARE 5000 Series All-in-One Software window, click Next.
c. Select CD Installation, and click Next.
d. Select I accept the terms of the License Agreement, and click Next.
e. Select Custom, and click Next.
f. Select Not Installed for every feature, and click Next.
g. When To begin the installation process appears, click Next.
h. Select Remind me later to register, and click Next.
i. When the Kodak Statistics Collection window appears, select Yes, and click Next.
j. When prompted, connect the printer to your computer.
k. Click Next when the Next button becomes active.
l. When Congratulations, your Kodak printer has been successfully setup appears, click Finish.
m. Click Continue, and then close all windows.
7. Before restarting the computer again, turn on the background applications.
b. Type msconfig in the Open field and click OK.
d. Under Startup Items:
- If only some items were originally selected, select the check box in front of the items that you noted in Step 5-c.
- If all background items were originally selected, click Enable All, and click OK.
8. Restart the computer.
Posted on Jan 08, 2009
Hello, I have a problem slightly different from these above. I bought a Kodak Easyshare 5000 series AiO printer scanner and the CD drive on my dell laptop doesnt work at all. I have had it repaired by the IT specialists but it will never work now. How do I INSTALL my printer without the CD????
Emily Heimerle
Posted on Oct 27, 2012
  • 154 Answers
Answer
External Audience: Everyone-External Internal Audience: Everyone-Internal To perform a clean installation of the KODAK All-in-One Printer Home Center Software:
  1. If a USB 2.0 cable is connected to your printer, disconnect it.
    IMPORTANT: Do not reconnect the USB 2.0 cable until instructed to do so during installation of the software.
  2. Uninstall the KODAK All-in-One Printer Home Center Software:
    • In the Control Panel, select Add or Remove Programs (WINDOWS XP OS) or Program and Features (WINDOWS VISTA OS).
    • Select KODAK AiO Home Center from the list of currently installed programs.
    • Click Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA OS).
    • When the Install Wizard appears, click Next.
    • Select Remove from the drop-down menu for the "Kodak All in One Printer", then click Next.
    • Click Next.
    • Click Continue.
  3. Go to Clear Utility for KODAK Software to remove any KODAK All-in-One Printer Home Center Software files that may not have been removed during the uninstall of the software and that can interfere with the installation of the software.
    • Select KODAK All-in-One Printer Software from the drop-down list, then click Continue.
    • Read and print the instructions and click Download.
    • Follow the on-screen instructions.
    • When prompted, restart your computer.
  4. Install the KODAK All-in-One Printer Software, either from CD, if you have the latest version of software, or by downloading from the Kodak Web site, www.kodak.com/go/aiodownloads, free of charge.
Posted on Aug 11, 2009
Software disk will not down load can I down load the drivers etc online
Please go to the Kodak model ESP3 multi-function printer support page by clicking on the link below, or copy and paste into your browser.
Print the instructions for installationo of the software / drivers, then download and follow the prompts to install the Kodak ESP3 multi-function printer.
Make sure you select the operating system on your computer, ea XP, Vista or Windows 7.
Good Luck
http://support.en.kodak.com/app/answers/detail/a_id/36460/selected/true
Aug 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do i install a Kodak esp series 3 printer to a dell computer
Take the CD-ROM that came with the printer, and install the software.
If you have lost the CD-ROM disk, you can download the software from Kodak's web-site.
Oct 29, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error code 1-2036 on Kodak ESP3 printer
this error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Jun 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cannot download or install kodak esp3 aio drivers or software
either you have 64 bit op system or you dowmloaded the wrong driver on accident.
if this information helps please use fixa when rating. thanks
Apr 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I bought the Kodak ESP3 because I love the features. I can not get the installation disk to start. I get a message error (the 32bit operating system required is above Window XP Sp2 The 64 bit operating...
Need pc and os specifics. Does you pc/os meet mimimum specs ( listed below) ?
If so, try the web installation at www.kodak.com/go/software
  • MICROSOFT VISTA or WINDOWS XP-Home (SP2 or above)
  • CPU: Celeron
  • Clock speed: 1.2 GHz
  • Memory: 512 MB
  • Hard disk: 200 MB free
  • CD-ROM
Apr 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Software won't install on kodak esp3
Manually uninstall the software in the computer
Download the clear utility and run it
Go to ms config go to services tab hide all microsoft and disable all click on appy
delete the kodak folders in regedit
and restart the computer
Download it again
Mar 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
6,820 people viewed this question
jasbo
jasbo
