Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
Problem with motherboard
When ever i start my computer it goes directly to bios only after that i can run my computer. it show an error message the motherboard should be made jumper free mode. please help me to solve this problem
  • Chip Loon Ng
    Chip Loon Ng May 11, 2010
    Hi, please provide us with the motherboard model, so i can assist u....thanks
When ever I start my computer it directly goes to bios settings and it says *********** board frequency not set properly. I tried with every kind of frequency but it did not work out and also it takes long time to get start.
Mother Board - ASUS P4BGL-MX , I bought this 2004. Please give me the solution.
Posted on Jan 10, 2009
HI. I ve a NEC versa pro VA12J. When i start my laptop it starts with beep sound and shows BIOS screen with an error message: 0251: system CMOS checksum bad- default configration used. During this period,...
This "0251" error indicates that the CMOS (complementary metal-oxide semiconductor; a memory chip that holds data the computer needs each time it starts, such as the current time and the BIOS [Basic Input/Output System]) has become corrupted or damaged, typically because of one of these three reasons: A BIOS update has gone awry, a recently installed program incorrectly modified the BIOS, or the computer battery is running out of power.
If you recently upgraded the BIOS, the first thing you should do is edit the BIOS settings. The BIOS developer can help you access the BIOS Setup utility and configure the BIOS accordingly. Likewise, if you recently installed a program that may have modified the BIOS, contact the software developer for assistance in reconfiguring the BIOS for the new program.
If you did neither of these things, the culprit is probably a faltering battery. You can probably replace the battery on your own, but the process varies widely depending on the type and age of the computer. We suggest consulting the documentation that came with your computer or contact the computer manufacturer to determine the type of battery involved, where to purchase a new one, and how to replace it. You can also access the BIOS Setup utility and write down the BIOS settings to reconfigure the BIOS correctly after installing the replacement battery. Once the new battery is in place, you will have to reconfigure the BIOS and reset the system time, but the error message shouldn't appear again.
hope this helps
Jan 09, 2011 | NEC Laptop Motherboard (1580262530)
When i start computer first i see bios. and after bios computer says that it has system failur
If you receive the message "Error loading operating system" and before Windows was running normally, you can try to reinstall your OS with the repair option (if you can't access your hard drive then it's hdd failure). If your message appears before boot media is accessed, I would recommend you to reset BIOS settings by following the steps below:44a6f3c.jpg
Sep 06, 2010 | ASUS P4G8X Deluxe GD Motherboard
When i start windows computer sounds a beep and a information screen opens with system specifications and shows "A: Drive error Press F-4 to rsume" whats the problem with my board please?
This error comes due to the Floppy Drive error..pls check the floppy drive cable connector prperly connected or not ...If there is no floppy drive ..Go into BIOS setup and disable the floppy drive..Then this error wont come again ..
Thank You for using FIXYA!!!!!!!!
Dec 04, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Bios ROM checksum error (Compaq SR5237CL with M2N68-LA MB)
A BIOS checksum error can be caused by a nearly flat BIOS battery.
I would replace the BIOS battery first before attempting to upgrading the BIOS.
Some motherboard BIOS firmware is upgraded by running a program that has been copy to a DOS boot disk or the upgrage maybe done from within the BIOS setup. These firmware upgrage and instructions are on the motherboard WEB site, in your case the Compaq/HP WEB site. Make sure you select the upgrade for your model motherboard.
NOTE it is possible that if you make a mistake you could ruin your motherboard, if you are not sure seek help from a computer savy friend.
Use this link :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Sep 17, 2009 | HP Computers & Internet
Installaion error
First make sure thats what you want to do since xp is no longer made. If you still want to go ahead you have to make sure you have the complete install and directions. You will have to remove vista first. But check the specs if you bought the computer with vista already installed you will not have the right drivers in your computer to go backwards in versions. Good luck. The reason the error comes up is that the install is trying to remove a component that is needed for your computer to operate. If you had xp and updated to vista, depending on how it was installed it would have removed the xp driver when updating.
Sep 05, 2009 | Foxconn K7S741GXMG-6L Motherboard
Hi when I start the computer, at the beginning i get error messages like, sata drive not found press f1 to continue press f2 to reboot, but i tried both f1 & f2 still windows doesn't start goes back to...
hi...you can try to remove the battery of your motherboard..the battery is located somewhwere in the bottom of the motherboard..it will reset you bios settings to default.
Apr 14, 2009 | Computers & Internet
Soltek sl-k8trpro939, error message BIOS not Loaded,
To clear cmos you'll need to remove the cmos battery from the motherboard for about 5-10 seconds then replace. You need your motherboard disk in order to load the bios. If you do not have this disk then you will need to go to the board manufacturer's website & download the bios. Follow the directions they have at the site to make a bootable disk & then boot from this disk. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Soltek SL-KT600-RL Motherboard
Mistankenly i connect config jumper on fan connecctor
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Thanks
Dec 12, 2007 | Intel D945GNT Motherboard
Regarding External Hard drive
Could you tell us the exact error message?
Aug 28, 2007 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Motherboard
There is normally a system tamper reset within the bios settings somewhere. Alternatively try to reset by the JBAT1 terminal by putting jumper from pins 1-2 to pins 2-3 then back again and restart pc. You will have to set the time again and make sure the HDD is detected in standard bios settings and re start.
Jan 16, 2007 | ASUS A7N266-VM Motherboard
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
