Question about Philips Televison & Video
I cant get DVD RW disk to work in ny dvd recorder DVDR5500
  • L Jefferson
    L Jefferson May 11, 2010
    is it a DVD+RW Disc or a DVD-RW disc?
  • 376 Answers
This player only accepts DVD+RW rewritable discs. Some players are also fussy with which brands you use. If you are using DVD+RW and it isin't working try another brand of disc.Hope this helps.
Posted on Sep 05, 2008
How do you delete songs on a burned disk on windows 7
you cant delete anything that has been burnt to a disk unless its a its a dvd -rw
Short for DVD-ReWritable, a re-recordable DVD format similar to CD-RW or DVD+RW. The data on a DVD-RW disc can be erased and recorded over numerous times without damaging the medium. DVD-R, DVD-RW and DVD-RAM are supported by Panasonic, Toshiba, Apple Computer, Hitachi, NEC, Pioneer, Samsung and Sharp. These formats are also supported by the DVD Forum.
Jan 17, 2013 | Microsoft Windows 7 Home Premium 64BIT...
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
WILL NOT RECORD MESSAGE E 24 COMES UP DISCS DVD R AND DVD RW TRIED . LEANS CLEANER USED .PLAY BACK WORKS OK.
Hi
This player can only record on -R / - RW disks.
It could be that you are using +R / +RW disks.
Also disks need to be formatted in machine before they work.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Feb 14, 2011 | JVC DR-M1 DVD Recorder
It wont record on 16xdvd+r discs? what is the properdisc
  • Media Type that the unit will play CD , DVD , CD-R , SVCD , CD-RW , DVD+R , DVD-R , DVD+RW , DVD-RW , DVD-ROM , Video CD
  • Media Format PAL , NTSC
  • Recordable Media DVD+R , DVD+RW only.. It will not record on the more expensive and compatible DVD-R, DVD-RW.
  • I recommend burning at a slower speed such as 2.4X, 4X or at most 8X.
  • I had similar issues resulting in many "coasters" for drinks burning at a faster rate even with my computer. Although some disks are designed to burn at a faster rate, software and components sometimes cannot keep up resulting in wasted money and time.
  • It may also be the media (manufacturer of disks). No matter which DVR or Burner you may have certain hardware schemes do not like certain media. It is a trial and error process. Just make sure the store has a return policy for the disks if they don't work. I have never had a problem returning disks to Staples that did not work.
I hope this helps and good luck.
Oct 27, 2009 | Gateway AR-230 DVD Recorder
Will not record dvd's
There are different kinds of DVD recorders and different kinds of recordable DVD disks.   Your disk must match the format of your recorder.  (eg DVD -rw, dvd -r, dvd +rw, dvd +r).  Look on the front panel of the emerson recorder and see what emblems are printed on it.  Your dvd must match the kind.  Also, if a dvd is of the -r or +r variety and has been finalized you cannot overwrite/rewrite to it.  (From a quick web search it appears your dvd uses dvd -r.)
Dec 28, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Just bought, set up to record with TV and used a Memorex DVD+R
you can then only use the dvd-r cd's and not the dvd-rw disc
Nov 26, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Unable to record.
Have you initialised the disk? The manual states that for the first use a DVD-RW has to be initialised first.
Apr 08, 2008 | Toshiba D-R5 DVD Recorder
Dvd is unable to read disk that i recoreded on the lg dvd recorder
It would be nothing to do with the TV.
DVD RW discs only last for so long if you have re-written to them many times they may be just worn out. Or is it with all RW discs?
Are you trying to watch them on the same player you recorded them on or is it a different DVD Player you are trying to watch them on?
Feb 17, 2008 | Televison & Video
Sylvania dvr90vf dvd recorder
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Televison & Video Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
