Question about Amana ACS7270AS Electric Kitchen Range
Amana ACF 4215A
This model # might also be ACR422GA or ACF4225A
The unit takes 20 - 25 minutes to preheat. It's been driving my wife nuts ever since it was given to us a year or so ago.
Now it is giving an intermittent F1 Code on the display.
  • Amana Master
  • 19,396 Answers
Regarding taking too long to preheat, usually you have to replace heating element, try first unplugging power cord to see if you clear F1 error.
Posted on Aug 30, 2008
    Genius:
  • 1,847 Answers
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn’t high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn’t happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you’re gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel –don’t spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Where to purchase flapper for toilet #4215A in Canada
Canada eh?
Home Depot sell the toilet, so they sell the flapper. Rona would also carry it. Take the old one with you.
http://www.homedepot.com/p/American-Standard-Champion-4-Max-1-28-GPF-Single-Flush-Toilet-Tank-Only-in-White-4215A-104-020/204309839
Sep 02, 2017 | Home
Meade lx200 acf r manual
Many Meade telescope manuals are available here: http://www.meade.com/support/manuals/ . There are several models in the LX200 series. The manual for the LX200-ACF is here: http://www.meade.com/downloads/dl/file/id/11/product/0/lx200_acf_manual.pdf . There is also a model LX200-R; the manual for this model is at http://www.meade.com/downloads/dl/file/id/13/product/0/lx200_r_manual.pdf . I don't see anything about a model with both the ACF and R features in this series.
I hope this helps.
Feb 15, 2017 | Meade Optics
Preheating?
Standard problem with this unit sorry to tell you! I've worked on several.The main oven would take 20-22 minutes to pre-heat, even on the "rapid pre-heat setting". I was told by Electrolux techs that it is the way the range is designed because of the "hidden element." Very sorry to tell you I found this model to just be very Unreliable. To many issues......
Jun 10, 2013 | Electrolux EW30DS65GS Dual Fuel (Electric...
Used self clean program and door lock will not release - tried turning breaker off and on several times Model The Big Oven ACF4225A
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
ff
Sep 20, 2010 | Amana ACF4225AS Electric Kitchen Range
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Takes 20 minutes to preheat.
The unit seems to be working ok....usually the temp probe will reach temp in 5 minutes and it will beep....i sugg for cust to let sit for 15-20 mins for precise cooking.
Jun 11, 2009 | Kitchen Ranges
Maytag advanced cooking system oven does not preheat to correct temperature and fails to reach the correct temperature
Once you put the desired temperature, select a cook time and it should solve the heating issue. Atleast that what worked on mine.
Jul 25, 2008 | Kitchen Ranges
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Amana ACS7270AS Electric Kitchen Range Logo
157 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
