Cpu heat i have a sony vaio pcg-frv31 laptop. it is getting heat quickly which causes my computer slower and slower how to solve this problem
I have a sony vaio pcg-frv31 laptop. it is getting heat quickly which causes my computer slower and slower how to solve this problem.
Posted on Sep 22, 2008
    Master:
  • 763 Answers
Buy a notebook cooler to minimize the heat of your laptop
like this
cheers
CHARCOIS
Posted on Aug 30, 2008
Model# pcg 71318l
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 29, 2013 | Sony VAIO Computers & Internet
Sony vaio pcg-71318L overheating
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
Aug 30, 2012 | Sony Vaio PCG-71318L
Need a manual for Sony Vaio model PCG-632L
I have this laptop (the PCG-632L). My laptop shiped with the "Vaio Notebook Quick Start" manual for the "PCG-R505 series". You could seach the Internet for this manual instead of the "PCG-632L" manual. The manual says "quick start," but it goes into slightly more detail than the average "quick start" manual (such as changing RAM).
Nov 12, 2011 | Computers & Internet
I have a Sony Vaio Model PCG-5J2L. Lately, the fan has been really loud, and the bottom of the laptop has been heating up and it is VERY HOT. Also, the other day, it just shut down by itself while I...
That recall is for VPCF11 and VPCCW2 models. Your issue definitely sounds like a heat problem. Sometimes it can be a buildup of dust, fuzz, carpet etc especially if you use it on a bed or the floor. Check all the vents and make sure they are clear. If the fan is making abnormally loud noises, slight grinding it could be failing. Here is one, retails for about 35 dollars. Make sure you get one with a heatsink, better safe then sorry. It is not too difficult to replace, but if you are not comfortable doing it then it is best to take it to a computer repair store.
Jun 28, 2011 | Sony VAIO PCG-K33 Notebook
My sony vaio pcg-k33 shuts off by itself when i turn it on. i think its the video card cause the fan turns on and stays on when i turn the latop on. so maybe its over heating. Please help
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Buy a can of compressed-air, and give your computer a "blow-job", because a layer of dust inside your computer is blocking your heat-radiators, and thus is causing your computer to overheat.
May 07, 2010 | Sony VAIO PCG-K33 Notebook
Pcg-frv31 sony vaio i want a vista sound driver
Hi there!
You can Get here and check. There is a tool which will check windows vista os. Download all drivers! Cheers!
Nahid visit my website
Jul 11, 2009 | Microsoft Windows Vista Ultimate Edition
Sony Vaio PCG-K30 laptop does not work
By removing the heatsink and cleaning it, you may have wipe d the heat sink compund, or the heatsink is not well attached to the base and is not making full contact with the CPU.
Check for this two conditions, and correct them.
Everything should be fine.
Jun 10, 2009 | Sony (B99860307) for VAIO PCG-K series...
Cpu heat
Overheating is a common problem with laptops, and usually a bit of preventative maintenance is all it takes to keep it alive. The bearings on those fans are pretty durable, however dust (and especially pet hair) can build up and slow it down. The motor may still be good, its just that the fan blades are stuck.
Blow some air in the vent OPPOSITE the direction of normal air flow (In most cases it sucks from the bottom and blows out the back/side) and if you see dust bunnies, your doing good. Be THROUGH! Especially if you smoke in your house, this causes the dust to become brown and sticky. = )
Good Luck!
Oct 27, 2008 | Computers & Internet
Need to upgrade my vaio
hi there,
Sony PCG-GRS750 or PCG-GRS300 all go back to the sony ( PCG-8K1L )
Maximum CPU is Pentium 4 Processor 2.0GHz
Maximum memory is 512 DDR PC2700
Apr 09, 2008 | Computers & Internet
Computers & Internet Logo
246 people viewed this question
David Payne
David Payne
