Question about Hotpoint WMA40 Front Load Washer
Cycle finished but door won't unlock, please help
At the end of the cycle - the door locked and end lights stay on. The door lock light and end light remain on and the door stays locked.
How can I get the door open and get the clothes out please?
  • 958 Answers
Normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Posted on Aug 30, 2008
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Why does my Maytag Neptune washer door stays locked after cycle is complete.
sounds like the locker servo is having an issue there and may need replacement contact Maytag for a replacement part
Aug 22, 2017 | Washing Machines
Frigidare gltf1670as
You likely have a broken or slipped drive belt or broken spring on the belt take up arm on the drum. Appliance Parts.com has a lot of DIY instructions on how to get at the belt and make repairs.
Jan 23, 2018 | Washing Machines
Door stays locked and door lock light stays on Washer does not operate
Let the power be on. Look at the right end side of control panel:end of cycle, keep this button de-pressed for 3 secs. Your prob is solved.
Pl click if helped.
Apr 02, 2013 | Washing Machines
Doorajar liht and beeper sounds
It can be issue with faulty sensor or a wiring issue.Troubleshooting is required.
Click the help link shown below:---
Door Ajar Light and Dome Light Remains ON? http://whoisbyme.blogspot.in/2012/06/2003-mercury-sable-door-ajar-light-and.html
Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Thanks.
Jun 26, 2012 | 2002 Ford Explorer
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
My Samsung VRT washer was working fine. The cycle appears to be finished but the door remains locked. I get no response from any of the buttons. You would think that the washer wasn't getting any...
I don't know if I have the same model SAMSUNG front loader, but I have a similar problem. The door has decided to stay locked at the end of the cycle. I can turn it off and on and even send it through another cycle, but at the end of the washing, it drains, goes to END but does not go the extra step of unlocking, like it usually would about 1min after ending the cycle.
My clothese have been through about 6 different cycles, hoping it will magically clikc open at the end. I assume they are very clean, but getting dizzy.
Any help out there?
Aug 12, 2011 | Samsung WF337AA Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
542 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
