Question about Panasonic Televison & Video
Hi. I have a Panasonic Viera TH-50PX70B and I am connected to Sky HD via HDMI. In recent weeks It has developed very thin vertical lines down the middle of the screen. It started with 2 and has now increased to 5. Any ideas please?
    Genius:
  • 1,011 Answers
Sir,
something magnetic near the tv. move it and the line will go away. either that or heat damage...if its near a window or open fire place.
thanks
Posted on Aug 30, 2008
    Master:
  • 763 Answers
It must be heated by continous usage and the screen reacts about it. did you try this by playing a dvd or any player using your tv? try any of the following
1. use on dvd player or any.
2. contact the cable operator on this. see if it has conflict about the reciever.
3. contact the the service provider in panasonic or the technician who can fix the problem from the their shop.
4. look for warranty about this for the service.
cheers
CHARCOIS
    Genius:
  • 1,847 Answers
Check the Panel ribbon cables and re install
  • Legin Varghese
    Legin Varghese Aug 30, 2008
    Happend, also because a bad soldering connections in that module. Lines will come on and off. Probably 1 day will stay on. For last 2-3 years im seen that only on hlm and hln series. Probably
    happens on other models. but, i never seen that.
    Is not that hard to replace that module. You have to remove 2 screws from left side and 1 screw from bottom righ side of module and 4 of them
    from around dlp unit unpulg all cables ( i think
    3 cables ) that it. Same way install new one in.
    but you will need to adjust a module position to get picture to fill whole screen
    Brigadier General:
  • 3,614 Answers
Have you try adjusting all the settings, and checking the wire connections?
Panasonic pt 52lcx35
We recommend that you test other inputs and devices on the TV to see if the lines appear only on 1 device or type of cable connection.
Keywords: thin, red, pink, line, lines, bars, bar, vertical, up, down
Oct 22, 2013 | Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Panasonic Viera TH-50PZ800U drivers
No. Just connect it to your PC and choose in the TV menu correct input source.
Aug 09, 2013 | Panasonic Televison & Video
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
CAN I STILL WATCH SKY TV THROUGH MY TV WHICH HAS FREEVIEW BUILT IN
yes...via scart or hdmi (depending if you have sky hd) tv will need to be set on AV1 or HDMI channel when watching sky tv. normally selected on your tv remote with a button with a square and an arrow pointing into it or simpally AV written on the button.
Mar 19, 2010 | Sanyo Televison & Video
Mitsu 57731 problems have wide bar across screen
This is an ongoing problem with Mitsubishi DLP HDTV's contact the Customer Service at 1-800-332-211. Tell them this has been going on for a while and you want the TV either Fixed or Replaced. Ask for Adrianne Hardt, she is a Customer Service Manager...... TELL HER RICK GRIFFITH told you to call.
I am in the 4th week negociations with Mitsubishi over these exact problems. I purchased my 57" DLP HDTV in Aug of 06. Replaced the Lamp 3 times and have had 5 Service calls. I DO NOT have and extended Warranty. Mitsubishi provided me with the extention in writing and stated if any problem occurred again they would replace the Unit or provided monetary compensation.
Good Luck and be persistant.
Any of you can email me for from info and covette54@live.com
Feb 23, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Cant connect samsung RTS-HE10 home cinema to my samsung 40" tv, which has 1 HDMI port. I also have sky hd
Connect the RTS-HE10 via HDMI to the TV and the Sky+ via scart to the TV. Then get a stereo RCA to 3.5mm jack lead and connect from your TV's stereo RCA output (red/white) to the Aux 3.5mm jack (like a headphone socket) on the RTS-HE10. Select Aux on the RTS-HE10 when you want to listen to whatever is on the TV.
Dec 06, 2008 | Televison & Video
We have a panasonic viera flat screen tv which has developed a vertical blue line that runs down the middle of the screen. any ideas?
sounds like it could be your flyback going out (cost around $70.00) for part if you replace yourself!
Panasonic Viera 37 inch Plasma won't read DVD player
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
Mar 16, 2008 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
