Question about Bosch HBN 442 / HBN446 Electric Single Oven
I have a Bosch HBN 7305.0 B oven. last night while grilling some fish the display changed to ERR: 15. I now have the oven locked shut and am unable to remove the food. How do I open the oven door because I will not be able to get in touch with a local (Jersey) service engineer before Monday morning.
2 Suggested Answers
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
SOURCE: My Bosch HBN 5605 .0B oven has a 15-20 degree
I detected a similar problem following the sudden appearance of Err1 in the display. (Oven 4-5 years old, and the grill element failed when it was 3-4 years old). This indicated a temperature sensor problem. My local dealer came with his Thermocouple and confirmed an "under temperature" reading on the standard and baking settings. I agree that the fan setting is probably OK. He replaced the sensor. I monitored the situation for a while and was not happy because an under temperature could be quite dangerous when cooking certain foods, and also causes problems when baking bread.
The location of the oven sensor is also a problem because it is at the top right by the grill which also serves as the top heat source.
I had corresponded with Bosch about this and their response was, frankly, less than satisfactory. In the end I decided to call out their engineer (cost £85-ish) who wired my oven up to his computer. In the end he said that the oven was working as it should be (despite it taking a very long time to actually reach the target temperature of 200C.
In my view of I want 200C, then I should get 200C, not an approximation.
Interestingly the secret info (not in the manual) is that the temperature bar readout does not indicate that it has reached the actual temperature, but may be 90% of the temperature (so if you want 200C you get 180C.
An unsatisfactory solution is to get an oven temperature of the meat probe type and put that in the oven, then you will get a more accurate reading of the temperature. You would need one that goes above 200C (my first one only goes to 200 but I have found another that goes to 250C). Mine is by CDN model DTP482, any good cook shop should stock this.
Andrew Finch
Posted on May 05, 2010
HBN 5605.0B power failure
Unplug the oven , then ohm out the heating eliment. My guess is that it is burned open.
Jul 13, 2014 | Bosch HBN 430560B / 430520B Single Oven
Touch keys on Bosch built in over HBL33 not responding
Not sure about your model but I have a bosch hgs7152uc model. I found that removing two screws and the metal panel in rear of the stove (at top where display is) will provide access to the control panel. There are four screws holding the display circuit panel in place. Two of the screws were not tight which allowed the circuit panel to move backwards when pressed. Tightening all four screws made the display operational again. The screws had lock tight on them but apparently they came loose anyhow over time
Oct 26, 2013 | Bosch HBN 442 / HBN446 Electric Single...
My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
The glas bulb cover at the top of the grill/top oven has broken leaving the glass edge stuck in the thread. I have a replacement but cannot get the old remnants out. Do I have to call an engineer to...
take a wooden stick about the same diameter as the broken bulb; place a washchoth over the end; push the stick into the bulb base in the oven and, turn the stick counter clockwise until it comes out. the stick is an insulator so you won't get shocked and, the cloth grips the bulb base.
Jul 31, 2010 | Bosch HBN 9061 / HBN 9021 Double Oven
My bosch oven grill element is not working and my oven does not seem to be getting as hot as it should. any ideas what it could be.
More than likely the grill element has failed, and this could account for the oven not getting hot enough, as on some makes, the grill element is on at the same time as the oven element, so if the element has failed, then it will not be hot enough.
My advice would be fit a new grill element, and this hopefully will solve the problem of the oven not being hot enough.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Bosch HBN 430560B / 430520B Single Oven
Can I change the grill element myself? I assumed it just plugged in at the rear and have removed the two screws holding element to top of oven. Now I wonder if the steel plate at the back is itself bolted...
The grill element is not usually a 'plug-in' device.
You will have to remove the back of the oven/grill and disconnect it from the back before you can withdraw it from the front.
Remember to switch off the power before removing the back.
Jan 12, 2010 | Bosch HBN 131560B / 131520 hot-air...
My Bosch HBN 5605 .0B oven has a 15-20 degree undertemperature when operating on the conventional baking setting - all other settings are ok
Andrew Finch
Jan 02, 2010 | Bosch HBN 430560B / 430520B Single Oven
No heat?
hi there sounds like fan oven element at back, don't worry about smoke from grill is more than likley just grease burnning off element, just leave on for a min or two
Feb 29, 2008 | Bosch HBN 131560B / 131520 hot-air...
Bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Dec 08, 2007 | Ovens
Fan oven not heating, bosch hbn 202t
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Bosch HBN 442 / HBN446 Electric Single Oven Logo
95 people viewed this question
Top Bosch Ovens Experts
bosch5
Dan Webster
Dan Webster
Chris Hall
Chris Hall
Are you a Bosch Oven Expert? Answer questions, earn points and help others
