Question about Palm Treo 600 Handheld
Can you change from Palm to Outlook on your Treo 600
I have Outlook on all of my machines. I have all of my contacts on the Palm software. I would like to import my palm contacts to outlook and run outlook on my Treo 600. Can I do this? How do I do this?
    Master:
  • 473 Answers
Simplest method for 'switchers': Assume that your Treo 600 has the data you need (it does but you are focusing on your Palm Desktop in your question). Install the Palm Desktop software again using the CD but this time, choose the option to synchronize with Outlook during the installation process. This will switch the synchronization to Treo <-> Outlook instalead of Treo<->Palm Desktop. Assuming your Treo is recently synched with Palm Desktop, this will merge the data you have in the Treo with that of your Outlook profile.
Posted on Sep 11, 2005
Palm Treo 680 won't upload to Vista
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Sep 03, 2008 | Palm Treo 750 Smartphone
Outlook Calendar synchronization failed in palm treo 650
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
cropp
Feb 24, 2008 | Palm Treo 650 Handheld
Unable to hotsync treo 600 with my computer
What is happening with the Sync? Does your PC and the Palm Desktop Manager recognize your TREO 600? If not, the issue may be that somehow the driver for your device was removed. I would suggest upgrading to the latest version of the Palm Desktop Manager and try plugging in your TREO 600 again and try synching.
Here is the location for the free software from Palm. http://www.palm.com/us/software/palmsoftware.html
You also have to make sure that the setting on the Palm Desktop Manager is the same as the type of cable you are using. If it is a USB cable, have that setting on your PC's Palm Desktop Manager Hotsync settings.
Jan 27, 2008 | Palm Treo 600 Handheld
Outlook Express
You cannot sync treo with Outlook express because of the Outlook express limitations However you can sync with Outlook
Sep 12, 2005 | Palm Treo 600 Handheld
Was there another solution?
I tried the conduit updater with no success--I wouldnt bother doing it.
Sep 12, 2005 | Palm Treo 650 Handheld
Cannot sync with outlook
You need the CD to get the Chapura PocketMirror Standard conduits. The conduits for Outlook are not part of the desktop download due to copyright protection. You need to obtain the actual CD by contacting palmOne tech support via phone. They will send you a CD for a small fee. If you happen to have a Treo 180,270,300 or 600, the desktop software download for these models includes Chapura PocketMirror standard version as part of the download but you need a serial number for one of those products to get the download.
Sep 12, 2005 | Palm IIIe Special Edition Handheld
Hotsync with outlook
Inorder for you to be able to hotsync, you will need a conduit and OE does not have one. It is time to move to msoutlook.
Sep 11, 2005 | Palm Treo 600 Handheld
How do I purge contacts from the Treo 600?
Best would be to perform a hard reset. This will delete all your contacts, but also all your other data on your phone as well such as mail, sms, call log, settings etc.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Sep 11, 2005 | Palm Treo 600 Handheld
    Synching treo 650 with 600
    In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
    Sep 11, 2005 | Palm Treo 650 Handheld
    HotSync Outlook 2003 with Tungsten E
    I tried all the suggestions that were offered and gave up. But then out of pure craziness I loaded the treo 600 CD that came with my Treo 600 out of curiosity. It loaded and the MS Office 2003 conduits loaded nicely and the problem appears to be solved for now. So I tested and it the Tungsten E Hotsync's feature all appear to be okay. I'm not sure if this is the best solution but it solved a very frustrating problem. The version of Hotsync that loaded is 4.1.0. Hope this helps.
    Sep 11, 2005 | Palm Tungsten E Handheld
    Palm Treo 600 Handheld Logo
    126 people viewed this question
    Top Palm Computers & Internet Experts
    Marvin
    Marvin
    JC Meredith
    JC Meredith
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
