Question about Compaq Armada M700 Notebook
Laptop only works with mains power supply connected
My compaq armada only works when its connected to the mains supply yet battery says its fully charged and has been tested and its perfect
  • judyelm Oct 18, 2008
    same exact problem
  • 54 Answers
When you power your system up do you get a message saying battery charge failure or some other disappointing driver message? Try powering down, removing the battery, and look for a little button on the underneath of the battery. You should be able to press this button and a series of lights will or won't appear. If they light up it means the battery is truly charged. If not there is something wrong with the connection. Try wiping the surface off and replacing the battery. Also make sure the pin that you place into the laptop to charge the battery is free of dust, etc.
Posted on Jan 14, 2009
I have a Compaq M700 lap top. power failure , Won't boot up ?
You need to find out if the power supply was damaged, it would have been the first to take a hit, remove the main battery to see if it will boot because a bad one will load the system down in some cases. One trick that might work, unplug power supply from laptop and remove main battery, now press and hold power for 2 minutes to drain off residual voltage and reset the processor, finally install everything back and power up.
May 03, 2012 | Compaq ARMADA M700 PIII500 MHZ LAPTOP...
My laptop is compaq Armada M700 with Windows XP Professional version 2002, how will i know if my battery is already fully charged? i have been charging it for a day and when I disconnect the charger tha...
From your description it seems the battery hasn't been charged right, so there maybe something wrong with the battery or laptop. First, do a clean to the your Compaq Armada M700 battery and the connection chip on your laptop, then to see if there is something get better. When you charge you laptop, there will be a lights to note the state, do you have noticed? Else if your Compaq laptop battery are used for 2 years please try a new one
Aug 25, 2011 | Compaq Armada M700 Notebook
Compaq Armada 110 works only, when AC adapter (PSU) is connected. I changed a new battery (refurbished) and now fully charged, but when unplug AC cable power will be lost. It was same behaviour with the...
OK, check the connection IN the laptop make sure they are actually making contact and are actually working. Now IF that is all in order, then I suspect, that your Battery Charger/Internal Power Supply, has faulted, the External and Internal supplies are separate, with exception for tap off to battery charger.
I have had this many times in my shop, you can most likely buy the Power supply sub board assembly and replace it.
Below is a service manual that will show you what to do and the part numbers. Most likely Ebay will be your best bet, or go straight to Compaq or Compaq dealer for the spare parts, or use the 'net.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+110
If you don't wish to DIY, then please get a "Quote" from a Compaq repair Centre
Oct 15, 2010 | Compaq Armada 110 Notebook
Computer worked fine last time i used it about 2 months ago, now it will not power up, any suggestions? compaq armada e500
Sounds like the you might need to replace the battery. Also check the power supply reconnect make sure connection are tight etc... its a long shot but make sure wall outlet is also active as well! Sometime it takes 20- 30 mins for an old battery to begin to recharge:)
Jul 25, 2010 | Compaq Armada E500 Notebook
Compaq armada 110 battery not charging at all laptop works on power supply perfectly but when cable removed no charge in battery, new battery purchased same problem how can i resolve please
I'm sorry to here this but in this case you must bring the laptop in the manufacturers service center because they have to replace batt terminals for it to charge them again. It happened to my cousins laptop.
Apr 06, 2010 | Compaq Armada 110 Notebook
I have a Compaq armada m700 and i dont know the power up password i put it in without realizing it
I'm copying someone else's answer; I can't vouch for it.
emove the main battery and mains power supply, hit the power switch to drain any retained charge. then remove the cmos battery and short out the contacts. the cmos battery is on the right under the panel at the top of the keyboard, which can be popped out by gently levering it up at the edges. the key board can then be folded clear, watch for the ribbon cable under it that connects to the motherboard.
Dec 14, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Always start with the simplest solution first so start by cleaning all the contacts, AC adapter laptop plug, laptop socket, laptop battery contacts and battery contacts. How have you confirmed power output from the AC adapter? have you used a voltmeter to ensure you are getting power at the laptop end? Have you used a voltmeter to test the battery? Assuming you have tried all this don't forget that almost any component can interrupt power on some laptops, however you're 2 main culprits with this kind of problem are usually power controller (voltage regulator) and in some cases, on a laptop of this vintage, the charge controller built in to the battery. Try it with a different battery if you have one.
Aug 10, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Wont recognise battery
Those may have 1 or 2 different problems. Cold Solder joint on Mobo. Bad DC Power Jack. 1: if it is the Cold Solder, you can reflow the solder and be done with it. 2: if it is the DC power jack, It should be replaced. For simplicity lets call them DC(A) and DC(B) There are 3 connections to it. Gnd, DC (A), and DC (B). When the powersupply is plugged in, contacts (A) touch to send +DC to the laptop. (B) is open. When the laptop is using battery power, contacts (B) touch to send power from the battery through the system. Over a period of time (inserting and removing the DC Power Cord), the contacts become fatigued, or oxidized and the DC(B) never closes - so it won't work from DC Battery. RATE ME - if it helps
Nov 26, 2006 | Compaq Refurbished Notebooks: Armada M700...
Compaq Armada M700 Notebook Logo
120 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
