Question about Palm m125 Handheld
Problems syncing to Outlook on new laptop
1. Long time Palm user on the desktop (now out of commission) 2. Bought a lap top - WIN XP home 3. Installed new MS Office - Outlook 4. Installed latest desktop manager from palm.com web site 5. Plugged in USB port cable 6. Hot Synced 7. Thought I set Outlook as default manager 8. Desktop manager filled with my data - don't want it there. Want it in outlook. 9. On my desktop, I used to have to give permissn to allow access for a number of minutes to hotsync....could that be part of the problem? I don't get a prompt if I want to allow access.
  • 473 Answers
SOURCE: won't sync to clean Palm
You may need to enter your user name in your "clean palm"
Posted on Sep 11, 2005
  • 473 Answers
SOURCE: HotSync Outlook 2003 with Tungsten E
I tried all the suggestions that were offered and gave up. But then out of pure craziness I loaded the treo 600 CD that came with my Treo 600 out of curiosity. It loaded and the MS Office 2003 conduits loaded nicely and the problem appears to be solved for now. So I tested and it the Tungsten E Hotsync's feature all appear to be okay. I'm not sure if this is the best solution but it solved a very frustrating problem. The version of Hotsync that loaded is 4.1.0. Hope this helps.
  • 473 Answers
SOURCE: How do I switch from HotSync with Palm Desktop to HotSync with Outlook?
I believe you need to un-install the Palm software and then re-install it - make sure you use the Custom Install - as that is where the "Sync to Outlook" box is to be checked
  • 473 Answers
SOURCE: How do I HotSync a Palm Vx with Outlook 2002
I wish I had found you two weeks ago! That help, though simple, was fantastic - thank you. I had no idea that Pocket Mirror was on the CDROM as it was set on autostart so it launched into the Palm Software installation straight-off. I've got a few problems to sort out with it but so far it has Sync'ed the: Addresses To Do Email not yet read Calendar ** It insists on spending a very long time thinking about 'backing-up' the handheld databases and I have to force it to close. Any ideas how to solve that little problem? I'm just about to leave for Paris so I can't pursue this anymore today, so if I may I'll follow-up at the end of the week. Meanwhile thank you for your quick response and excellent instructions. Regards
futureloginn
  • 734 Answers
SOURCE: How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
Transfer calendar info from Tungsten/E Palm to iphone 3GS
The best way is to transfer the Calendar and Contacts to Outlook. The iPhone can then be synced with Outlook.
Unfortunately, tasks and memos do not transfer. You will need to find other 3rd party apps that are supported on the iPhone and transfer your data to them.
Two examples are:
1. Evernote - This is good for memo. You can export your memos and then import them into Evernote. unfortunately, when I did this, it was a bit tricky. I even had to write a little PERL script to create the format that it wanted.
2. RemembertheMilk - this is a todo application
Jan 03, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Tungsten E - HotSync with Outlook 2003
Don't skip the initial HotSync for secondary computer! Alright, I figured this one out on my own and figured I'd post what I'd learned so that others don't have to endure the teeth mashing, hair pulling, snarling frustration. (self induced as it may be) My experiences have taught me to not always trust a cookie cutter installation wizard...especially for custom app installations (ie: primary = home, secondary=work, total sync, no priority). So, I did not perform the initial sync during installation of the palm software fearing that the new installation would NOT recognize that the work computer was a secondary machine and resultantly wipe out the old palm data from the primary machine. Turns out, as I saw in many other unrelated posts, that it's difficult (if not impossible) to specify conduit direction to outlook 2003 outside of the initial sync (this prompted me to specifically look for conduit direction during install). So, this wizard is one I should have trusted...by mistake...because of weak program design. By the way...once I specified sync with outlook during the initial sync, EVERYTHING works fine despite not having installed the two "imperative" conduit updates (they were uninstalled after several previous failed attempts at this). Hope this helps
Sep 12, 2005 | Palm Tungsten E Handheld
Sync Doubling Calendar & Contacts in Outlook 2002
your t5 is UNSTABLE possibly due syncing to an old username from an old PDA. To correct this: -delete manually the doubles (PDS has a tool but none for outlook) -perform hard reset on your t5 -hotsync - creating a new user name (do not use the old one) -you will be asked to use the same profile name for the outlook Then you should be good to go.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Tungsten E and Outlook 2003 sync problem
yes I moved my files to a new machine and reinstalled palm (which of course also created the dreaded multiple copies of many palm contacts, when palm discovered older archives, but that is another story!) I wouldn't mind that if the palm pilot would just sync with outlook 2003. It synched with Outlook 2000 on my old machine.
Sep 11, 2005 | Palm Tungsten E Handheld
Syncing with Outlook 2003 problems
Download the Outlook Security Add-in from this site: http://www.mapilab.com/outlook/security Advanced Security for Outlook is free for commercial and non-commercial use. I have testet it with Windows XP and Outlook 2002 SP3 syncing with a Palm Zire 31 and it works fine.
Sep 11, 2005 | Palm m505 Handheld
Sync Outlook 2000 with 2 user accounts, 2 PDA, in XP
One Word
DONT!!!!!!!!!!!!!!!!!!!!
Palm can't think that fast.......especially with 3rd party!!!
Sep 11, 2005 | Palm III
How do I coordinate different user profiles on 2 pcs?
You will have to keep the profiles the same. In Palm Desktop, under Tools/Users, you will need to reset the name on both of the computers to match the name used on the PDA.
When you start syncing to two computers, the Windows conduit will start to complain. Just tell it that you know, and clean up the mess by yourself.
Which is only one of the reasons I don't use Outlook at home. Palm Desktop can remove the errors created by Outlook, but Outlook can't.
Sep 11, 2005 | Palm Tungsten E2 Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Zire 72 and Outlook 2003 - I think I've tried it all! Doesn't work....
you don't need pocketmirror for zire 72 because palm desktop have outlook conduits to handle outlook synching. inorder for you to sync using outlook you must have the outlook conduits installed which seems you have it already installed. you have to disable some older conduits inorder to avoid conflicts with the conduits. to do these follow these steps: 1. right click on the hotsync manager icon on your system tray 2. click on Custom... 3. select Date Book (Outlook) 4. click on Change... 5. select Do Nothing and set it to default 6. click Ok 7. repeats steps 3-6 for Address Book (Outlook), To Do List (Outlook) and Memo Pad (Outlook)
Sep 07, 2005 | Palm Zire 72 Handheld
Sep 07, 2005 | Palm Zire 72 Special Edition Handheld
Palm m125 Handheld Logo
66 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
