ILO-32HD No stuck buttons. I have a picture and can change channels using cable box. Cannot access any other function using remote or buttons on TV, but the remote will turn the TV on and off.
  • tjmishey Aug 31, 2008
    There's no link to click on.
  • tjmishey Sep 06, 2008
    abrsvcs(Dan), any suggestions?
  • 13,433 Answers
Hey,
I got your comment about problem not solved, go back into the premium, and click on the link which says request more assistance, there has been a better solution posted after mine, by expert - abrsvcs
Posted on Aug 31, 2008
  • Ekse Aug 31, 2008
    noticed you found it. you are possibly now viewing the solution by techexpert12 - after him is abrsvcs(Dan) I highly recommend you stick with DAN, he can solve your problem im 100% sure of it so make sure you don't skip over hes solution and if he solves your problem remember to accept hes solution so he can be paid.
  • Ekse Sep 06, 2008
    you can ask him herehttp://www.fixya.com/users/abrsvcs
    select the free option
I have an ILO 32HD and the HDMI input does not seem to work.. goes from no signal to HDMI 10801 but i get a flash of a picture somtimes.. My first HD and can't see it!!! I have tried 2 NEW HDMI cables...
HDMI issues are almost always the scource and not the TV. If HDMI fails to work then use the component inputs as your picture will still be in high definition when on HD channels..
Nov 11, 2009 | Televison & Video
TV is stuck on one channel and won't change even with remote.
Ii would begin by changing the batteries in the remote. As they lose their power they will control some functions but not others. If that doesn't solve it, get back and we can take additional steps. i want to help.
May 23, 2009 | iLO 3200 32 in. LCD Television
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Ilotv 32HD
The only way that I know of to eliminate this problem is to buy a new TV. My ILO TV has been repaired twice since May 08 and it went out again for the third time. The problem starts out as an intermittent problem.... You turn the TV on, the audio is fine but there's no picture, you will be unable to change the channel or volume whether you're using the remote control or the buttons on the TV.
This TV should have been recalled. Don't throw good money after bad and don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Sep 17, 2008 | iLO 3200 32 in. LCD Television
ILO-32HD
Normally this is a good indication of a stuck button on the set. With the set off, try working each of the control buttons. You should be able to feel teh button engage. If one feels like it does not work, that is the likely culprit and it should be replaced.
Let me know your results.
Dan
Sep 07, 2008 | Televison & Video
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Jan 04, 2008 | iLO 3200 32 in. LCD Television
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Cannot change channels
Hi! I have been through this situation on a 26" model of ILO LCD TV. I think the problem you have is the same, but could you clarify one thing for me? Is your model an ILO-3200, or is it an ILO-32HD? I suspect 32HD, because I know the problem exists on the 26HD models which are basically very similar in design and say manufactured by Initial Technologies on the back of the set. Does your unit list this manufacturer on the back? Let me know. Thanks!
Sep 30, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
