Question about Hoover Vacuums
My brushes don't rotate on the on position. I have a SteamVac V2.
  • 706 Answers
Do you hear the motor for the beater bar brush running? If so, you'll probably need to replace the brush drive belt.. If not.. you may have a broken wire suppling power to the brush motor.. or the switch is bad.. Hope that helps..
Posted on Aug 31, 2008
  • Rick Gelin
    Rick Gelin Aug 31, 2008
    I almost forgot... are all the connections properly made that supply power to the brush head?
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
How do I install the belt on my steam vac V2 model f7210-900
STEAM vac don't have a belt they rotate by turbo motor that sometimes seize up click the link below and watch video how to fix.
http://www.youtube.com/watch?v=QBtWcC4gqjY
Aug 14, 2012 | Hoover F7210-900 SteamVac V2 Upright...
How to disassemble the hoover steam vac2. the hole that the brushes snap into does not rotate so the brushes are not rotating
The hole the brush shaft goes into is the turbine that turns it. If it will not turn it is seized and should be replaced.
Feb 03, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I have a hoover carpet cleaner model # F7427-900 series Z120 and the rotating brushes stopped moving. How do I fix this?
The brushe until needs to be snapped in very hard; to line up correctly. Pull the unti off and put it back in, good luck.
Jun 30, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My brushes are not turning
There is a plastic shaft on the back of the block brush (spin scrubbers), these wear out or break. You may need to replace the block brush. Or if the shaft is not broken it could also be the Turbine Gear. This is what the block brush shaft goes into. You can get access to it by taking off the hood. You can find the parts and a schematic below follow the link. Please don't forget to give positive feedback.
F72XX Link
http://www.usavacuum.com/Hoover-Steamvac-s/110.htm
Jun 23, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
My Hoover steamvac brushes do not turn
F72XX Link
Dec 25, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40473&thid=732696
Posted by mathis_23 on Jul 02, 2008
I cleaned filter and the brushes are still not rotating.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It probably is not the filter that will start the brushes turning again, it may be a few other things. There is a switch in the front that indicates brushes on and brushes off, and the switch could be broken, it could be that the brushes come in an assembly and the assm could be belt driven and you would have to replace the belt or the drive mechanism the turns the brushes is broken. These are just suggestions and you should check the schematic in your owner’s manual under trouble shooting. If you don’t have a owner’s manual, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes won't spin anymore.
I left you with a solution and picture diagram in the premium solutions, did you get it?
Mar 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
