Question about Minolta Office Equipment & Supplies
Printer will not work - Minolta Office Equipment & Supplies
    Sergeant:
    Champion:
  • 310 Answers
Can u explain me clearly
Reinstall the software..
Posted on Aug 30, 2008
  • khader ibrahim Aug 30, 2008
    If u reinstall the software means it will work fine..
Why has PIXMA MX410 printer stopped working? Re-installed Canon PIXMA MX410 All-In-One Printer on hp pavilion 23 widow 8 x 64, system would only print but menu solutions would not. Then printer stoppe
Driver issue. Uninstall and reinstall driver for win 8 64 bit - should work if same worked before. Did you try a system restore to time when printer was working properly?
Sep 11, 2017 | Canon Office Equipment & Supplies
Printer stopped working
Please check it power cable or power board, if power section ok or working.
Then check you printer connection or not.
Check printer cartridge shot or not detect.
Check it printer head, if header not working then not print coming.
Check it your printer driver installed or not, if installed may be some problems then your printer not working. So old driver delete or new driver installed.
If other issue please tell you.
I hope solved your issues.
Thanks,
HP Printer Problems
Jun 18, 2014 | Brother HL-2040 Laser Printer
Working printer will now not be detected windows xp
Do you have the correct XP driver for the Printer? If yes check that the cable that connects the printer to your system is not damaged. If you have another working system near by you can connect the printer to the system and confirm the printer is working. If the printer is still not working, the printer port may be bad either on the system or on the printer. In this case you need a technician to help you confirm which is the faulty one.
Jun 07, 2012 | HP LaserJet 4 plus Printer
My HP Printer no longer works on my laptop. What
you did not provided any useful information, what operating system you use, what printer, what connection (usb, paralel, network) and what laptop.
general advice only can be provided then.
if windows of any flavour, disconnect the printer, uninstall all software pertaining to this printer. use ccleaner and clean your harddrive including registry.
check printer on another computer if it works. if printer works correctly, problem is with your laptop, not with printer.
follow this procedure, install software, connect printer, switch printer on, windows will automaticaly install drivers and printer software
if this do not work, you need to check if port used for printer work with other hardware, ie, usb stick, check cable between printer and relevant port.
Jul 20, 2010 | HP Computers & Internet
Printer won't resond to command from computer
restart both printer and computer then report back if any changes
Nov 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Printer will not work with new computor
Be sure that your printer is compatible with your new computer
You have to install the printer on the new computer in order to get your printer working
Run the installation CD or download the printer program from the internet.
If you already have your printer installed and it is not working
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Nov 06, 2008 | Computers & Internet
Flashing lights
the printer when i on the swich the flashing light is on but can't work the printer
Feb 24, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
