Question about Lakewood 200I Floor / Box Fan
Broken grill Panels
Where can I buy replacement plastic (front & rear) grill panels for my 20" Lakewood Box Fans??? I have searched & searched Google and others and found nothing (no vendor supplying this part) Any one know a source would be most helpful!!
    Brigadier General:
  • 6,966 Answers
Pls try here and look for an authorized parts distributor near you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
  • Louie  Role
    Louie Role Aug 30, 2008
    An alternative is to contact them and inquire on how to go about purchasing the parts that you need.
    Lakewood Engineering & manufacturing Co.
    501 N Sacramento Blvd
    Chicago IL 60612
    email > custserv@lakewoodeng.com
    Cheers.
  • Louie  Role
    In case your browser will not redirect:
    OLORADO
    NELSON APPLIANCE REPAIR,INC. 1220 E. Fillmore COLORADO SPRINGS, CO 80907 Ph:866-635-1928 www.nelsonappliance.com
    NEW YORK
    YEMMA APPLIANCE PARTS, INC
    1962 TEALL AVE. Ph:800-962-7532 www.yemma.com
I have 2 Lakewood table top fans that need cleaning..I can't get the front grill off...the screws will not turn..how can I open this fan ????I am desperate
sounds like ya screws are stripped in the plastic housing if you can keep trying im sure the fan will open but if not go around the sides with a flat head screw driver till it pops open i got a few sorta like that once the screws are off go around the sides with a flat head screw driver and it will pop open
May 26, 2014 | Lakewood 2210 Fan
How do i remove front grille frame from skoda octavia
I have no idea how to remove the front grille of Octavia but to solve out your problem I found out one video which is showing to replace the new front grille with old or damage one. May this video helps you. Have a look
Apr 13, 2013 | Skoda Octavia Cars & Trucks
Lakewood 2210 table fan.. It wont come apart to clean the blades and such.
There are NO Screws holding the front grill on this model.
Hi, if you look inside the grill from the back side, you will see there are small snaps inside near the edge of the cover. The snaps go around the entire cover and are about 3-4" apart.
I used a flat tip screwdriver to get push the tab up from the back and the inside of the grill. When you push up the tab a bit, then slide a small flat tip screwdriver on the outside lip of the front grill. You will have to do this all the way around until the cover snaps off. Putting it back on is a breeze because it just snaps together.
***AS ALWAYS SAFETY FIRST !! NEVER WORK ON ANY APPLIANCE When it is plugged in !! ***
Hope this helps.... =)
Aug 04, 2011 | Lakewood WC-2000 Box Fan
Can I order new "feet" for Lakewood box fans
I searched for your solution. This is the closest I can find. This is customer service for Lakewood.
https://secure.jardenstore.com/ContactUs.aspx
Another solution if the above does not work. You could make a couple of feet from some wood as well.
Feb 06, 2011 | Lakewood 101 Floor / Box Fan
Switch broken
May not be identical but an appliance store or hardware store should be able to assist you with that. Home depot or Lowes as well. Take old one with you if you can.
Jul 10, 2010 | Lakewood 200I Floor / Box Fan
Need feet for 20" box fan
you can purchase the feet at lasko.com go to there parts dept. i think i paid 2.00 plus s+h.
Oct 16, 2007 | Lakewood 200I Floor / Box Fan
My Lakewood box fan fell over and stopped working
As the box fan is a simple electronic, I would take the fan apart and check the solder points. If one has broken loose or is cracked, simply re-solder the point. Test it and try again. Another suggestion would be to go to your local hardware store and find some appropriate L-brackets to secure the fan to the sill while still maintaining the ability to remove it and close the window. A little human ingenuity can probably outsmart a cat. ;)
Jun 27, 2007 | Lakewood 200I Floor / Box Fan
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
May 27, 2007 | Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
May 23, 2007 | Lakewood 200I Floor / Box Fan
Lakewood 200I Floor / Box Fan Logo
518 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
