Horizontal display the horizontal display of my aoc color monitor will not adjust even i adjusted it to 0% or to 100%...t
  • 65 Answers
To replace TIP122 at near by LOT.
Check any dry point of DMV32 or DMV1500(Damper diode).
Check flayback capcitor and boosting FET 634.
Posted on Oct 07, 2008
How do I reduce the brightness of my AOC monitor?
If you are using windows XP :
1.Right click on desktop
2.Properties
3.Settings
4.Advanced
Windows 7:
1.Open Display Color Calibration by clicking the Start button , and then clicking Control Panel. In the search box, type calibrate display, and then click Calibrate display color. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2.In Display Color Calibration, click Next to continue
Aug 01, 2011 | AOC Monitor
My monitor changes colors (e.g. normal then turns
Color changes on the display mostly occurs because of a faulty VGA cable or a loose connection of the cable to the VGA port at the back of your PC or Monitor. But if the cable is fixed securely at the back and the problem still persists, slightly move the cable's wire segment while observing its reaction on your monitor. Does it change colors while u do so? If it does even when the cable is securely plugged in to both the PC and the monitor, then u need to change the cable.
As for the visible display area size (technically called the Resolution) right click on an icon free area on the desktop and click Properties. At the top of the form click on the Settings tab. At the bottom of this form find Screen Resolution and adjust it to it your requirements and click Apply. On the confirmation dialogue that pops up click Yes if the displayed resolution suits u otherwise click No and try another resolution size. Hope this helps.
Nov 28, 2009 | AOC CT720G 17" CRT Monitor
Need schematic diagram for AOC 5 En model (white 15 inches color monitor) - thank's
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
Nov 21, 2009 | AOC 5 En 15" CRT Monitor
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
Monitor Curcuit Problem
re-adjust the vertical and horizontal size then exit the menu
Oct 22, 2008 | AOC LM729 17" LCD Monitor
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Problem in my aoc monitor
pls replace control button 4no
Jul 12, 2008 | AOC CT720G 17" CRT Monitor
AOC 5En monitor
replace new moitor....
Nov 13, 2007 | AOC CT720G 17" CRT Monitor
Computers & Internet Logo
493 people viewed this question
David Payne
David Payne
