I HAVE THE SAME PROBLEM I DOWNLOADED GEARS OF WAR ON MY XBOX 360 AND WHEN I PLAY IT IT SAYS DISC UNREADABLE EVEN THOUGH ITS A DOWNLOAD I TRIED REDOWNLOADING IT SO MANY TIMES YET IT NEVER WORKED
i had this problem with my xbox and its due to either the laser or the magnet within the disc drive that holds the disc in place. the magnet may have come loose which mean u can either open the drive up to try and reposition it, or replace the drive all together. my suggestion would be to send the xbox to microsoft if under warranty or send it to a third party company to see if they can fix it. buying a new drive for your xbox involves some very complex firmware flashing which is not advised
Ok, if you are sure this disk is readable and all the other disk work fine, this will confirm optical lens damage. i would replace this optical lens assembly asap. this will fix your issue.
You should know that, if the Xbox states that the disk is unreadable, it may be the disk. if you are positive that this disk is good, simply replace the optical lens assembly.
do other games work? if not your magnet in your xbox console disk drive may be defective and i would suggest returning it to Microsoft to have them look at it. If other games do work your fallout 3 disk may be severely scratched or the magnetic strip on it may have gotten demagnetized or otherwise damaged and will most likely need to be replaced...sorry
I do believe its a problem with the disk. The disk may not be scratched or anything but it could possibly something internally wrong with it. I'd take the disk back and exchange it. Hope this helped! Have a great day!
