Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Tring to place on computer but computer doesn't read the hard drive
When pluged in nothing happens
    Problem Solver:
  • 8 Answers
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Posted on Sep 02, 2008
When I click the power button on my harddrive the power doesn turn on. I removed all of the plugs and nothing happened
If your not getting any power use a multimeter on the hard drive power cord,, probe orientation doesn't really matter you just get a negative reading if it's reversed. One probe down the middle one of the metal on outside of power adapter. Can't get a probe down middle just stick a paper clip and just probe to that. If it is getting voltage then the dc jack inside the hard drive enclosure could have broken loose take something pointy and gently push the jack on the hard drive if it wiggles it's broken and needs to be re soldered. Comment back for more assistance if needed, General solutions below
Check the following
  • With the drive plugged in on powered on place your hand on it should be able to feel it vibrating (if no its not getting power or dead)
  • If power and vibrating put your ear to the drive (repeating and squealing are bad, crunching sound is generally ok)
  • With the drive plugged in and it sounds ok and it's vibrating[platters are spinning] right click on "Computer"/"My Computer" select manage > Disk Management, locate your drive if it is listed try to initialize it
  1. Right Click drive, properties, hardware tab, select drive, properties, volume tab and click populate
If it wont populate or doesn't show at all in storage manager at all either the drive itself is bad or the control in the external enclosure is bad. You can attempt to remove the drive from the enclosure and plug it in directly into the computer but this tends to void it's warranty. If the drive works however you can simply buy a new enclosure for about $12
Comment back if you need more assistance
Aug 30, 2011 | Western Digital 500GB My Book Pro-External...
Hey there. I have a problem with an external harddrive. "My Passport Essential". When I connect it to my compute sometimes nothing happens and sometimes "Local Disk (E:)" shows up in my...
The problem might be a loose connection or bad configuration file (an autostart ini file that makes the hard-drive do certain things when plugged in) in the root folder of your hard drive. Are you able to connect to it sometime or it doesn't work at all? If you can read it, try backing up all your data and format the hard drive and copy back the backup again. But remember to copy only the needed files and not the system or ini files.
May 06, 2011 | Western Digital My Passport Essential...
My Western digital My Book WD5000F032 is a 500gb External Hard Drive. I use to store, pics and movies. I did not back them up anywhere and are important. 1. I turned My Hard Drive off because my...
well it's good that you checked all of that, nice job always unplug from your PC when done and turn off ok this a must other wise they will tend to mess up like this, but try this ok go to (my computer) when its pluged in and on if you don't see it, then go to (control panel) and into the (admin tools) and then to (computer management) then to (device manager) look under drives and rightclick on your exturnal and go to properties and do an (update driver) if this fails, do a (disk cleanup) on your all drive connected check all boxes and run it. next do a defrag right after that and defrag all devices as well and then unplug your device restart PC and plug back in and see if it will rec. it and if it does go in to it and do the same thing a disk cleanup on it it's self and a defrag again and that should work if not comment back to me ok good luck and have a nice day the fixist !!!
Aug 02, 2010 | Computers & Internet
My computer can not find my second hard dirve. The drive I am tring to hook up is from my external hard drive. Some components of the external drive don't work however the hard drive is still good. I know...
go to the device settings and try to find it by scanning the usb port.when he removed the info was it still in the case .if not the problem is with the usb out-put board in side the unit.
Dec 08, 2009 | Western Digital 250GB MyBook External USB...
I purchased 2 WD elements 1TB. I have pluged it
right click on the drive , format it and it should work, if this not solves your problem go to the shop and use your warranty, it may be broken.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
My fantom hard drive was working perfect until i unhooked it to move the computor to another area of the house. now when i pluged it up nothing happened. i may have plugged the usb upside down but not...
First of all you cannot plug the USB upside down. it always will go only in one direction. as for the **** try right click my computer/manage and see if the disk is been recognised? if not you have a driver issue or a disk issue.
Jun 09, 2009 | Fantom Drives 120 GB Hard Drive
Does not connect to computer
i have the same problem too. if anybody know the answer to this please call me at 3165167004. I will real appreciate. leave me a message if possible
Oct 29, 2008 | Western Digital My Book Essential Edition...
Compaq computer doesn't boot, no BIOS post screen/no video or beeps
welcome to fixya
does the computer turn on?
do any or the lights come on or is it just dead?
if compute does not turn on then you might want to make sure ever thing is plug in ...
if ever thing is pluged in and and still does not turn on this might be the power supply has gone bad ...
if computer turn on and nothing happens this could be a bad hard drive or the OS has messed up first try to but in your reboot disk this still nothing happens then the hard drive could be broken
hope this helps you out have a good day
Aug 04, 2008 | Compaq Computers & Internet
Maxtor one touch mini doesn't appear to work.
The blinking light indicates something is happening to know open :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=1600
And check the power cord and try with the known good power cord.
You can check this :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4996&p_created=1194886713&p_sid=SzkLKr3j&p_accessibility=0&p_redirect=&p_lva=1600&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTg0LDE4NCZwX3Byb2RzPTQxMCw0MjEsNDYxLDQ2NSw1MDgmcF9jYXRzPSZwX3B2PTUuNTA4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1
Good Luck.
Live, Love, Laugh.
Feb 16, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
82 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
