Question about 2wire 1800HG Router (RG1800HG00)
1800HG ROuter + Home Network
Hi there
I have a BT 1800HG router with 3 laptops connected wireless and the internet works fine.
3 laptops has Windows XP
Can I use this router to create a netwrok among the 3 computers? I want to share files, share printers and allow my kids to play games.
Thanks
Rather than try and explain how to set things up here (would be a rather long answer!)... follow the links below ;)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Go here for instructions on setting up printer sharing
http://www.home-network-help.com/share-printer.html
go here to setup file sharing
http://www.practicallynetworked.com/sharing/xp/filesharing.htm
Posted on Oct 16, 2008
  • NeMeS1S Oct 16, 2008
    er... sorry about all the rubbish above... copy/ paste did something wierd there I reckon!!!
Does it need a modem or works on it's own ??
It doesn't need a separate modem; it replaces a modem in your home network. If it's properly connected to the phone line, and you have an internet service provider (ISP) supplying you with a broadband connection, and the PC is connected to the router, then it should all work fine.
If it isn't all working fine, the most likely problem is either that the wires aren't connected in the right places, or that the PC's internet connection isn't set up properly (e.g. if you changed from dial-up with a modem to broadband with a router).
If you have recently changed from dialup to Broadband, and you're running Windows, use the Network Connections wizard to set up the internet connection. In Windows XP you can do it this way:
1) click on Start
2) move the mouse to Settings
3) click on Control Panel
4) double click on Network Connections
5) click on File
6) click on New Connection Wizard
7) follow the instructions.
Your ISP should have sent you a CD-ROM to help you to connect, so insert the CD when prompted by the New Connection Wizard.
Sometimes you can just insert the CD into the computer and you'll be prompted to do everything necessary to connect to the internet. BT, for example, do it this way.
Oct 09, 2010 | Trendnet Wireless Home Router TEW651BR
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Wireless G Desktop Card Connection to BTHome Wireless Router
uninstall the bt desk top help first then the bt wireless connection , if ur wireless card has an utility use it to configure . the connection might be due the conflict between the wireless software. checked if ur getting limited or no connectivty if so delte and recreate  the wireless profile, if ur using bt router like home hub or voyager go the router page with the ip for hub its 192.168.1.245 and navigate to advance and keep the wireless channel to 9 or 11  for voyager the its 193.168.1.1
Oct 21, 2008 | Belkin 802.11g Wireless Desktop Network...
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Unable to actually connect to the internet?
Have you tried restarting your router? If not, try unplugging the ac power from the router, wait 30 seconds, and plug it back in. That will usually take care of this problem. If that doesn't work, you can try going into "manage your wireless connections", delete your wireless network from the list, then reconnect to your network.
May 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Limited or no connectivity
make sure wireless switch on laptop is on. since you are using XP, type services.msc on the run box, on the services local page go to wireless zero configuration, check if it has started automatically. then go to your wireless area connection, r. click then view available wireless networks. you shall see your 2wire network as 2wirexxx, where xxx stands for the last 3 nos. of your modem's serial no. connect to that network, it will ask you to enter the wireless key or passphrase. now type in the default wep key, that is the 10-digit nos. at the bottom of your 2wire modem right below the sn 7 it is enclosed in brackets. if you still has limited or no connectivity, check the modem if it is set to use default wep-open encryption. it is done by going to homeportal/management, type your system password, it will lead you to the management & diagnostic console page (mdc), click on wireless under local network. pls check if wep encryption is set to open and it is selected to use default encryption. you can also change the wireless channels & power settings, then click on submit. now try to connect.
Note: you can do the mdc on the desktop.
Apr 08, 2008 | 2wire HomePortal 1800HG Router...
Bt 1800hg
You'll need a way for your computer upstairs to connect to the hub/router. You can most likley get away buying a low priced wireless USB adapter like this one. http://www.newegg.com/Product/Product.aspx?Item=N82E16833340004
If your router has wireless security (such as WEP Encryption) you'll have to know the (WEP) key and SSID of the device in order to connect.
Feb 23, 2008 | Computers & Internet
Desktop unable to launch internet explorer
If the laptop is working then your router is probably working correctly. Is the desktop wired to the router or running wireless?
Feb 20, 2008 | 2wire 1800HG Router (RG1800HG00)
2wire 1800HG Router (RG1800HG00) Logo
144 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
