Hi could u help me please am doing my corse work on a cd on my laptop and when i save it. it says save as txt and nothing else and when it saves it just comes up as lots of letters and numbers and other things how could i fix this problem thanks
  • Jenny
    Jenny May 11, 2010
    Can you give a bit more information. What programme are you working in ie word, powerpoint etc. Also are you saving to disc and then trying to read files on another computer or on the same laptop.
    As a quick try - save file to the laptop first, then open saved file - is it still coming up as nonesense? If it opens ok then try copying to disc and see what happens when you open it from the cd.
    Scholar:
  • 87 Answers
Sorry can't really advise with the information you have given. If file opens as normal when saved directly to the laptop hard drive then it's not a problem with the actual file. If you are working on a file and then saving it directly to disc have you made sure that the disc has been formatted first?
Posted on Nov 11, 2008
Saving to notepad
Use MS Word or any other text editor to type the document and save it as .txt or RTF.
Jun 06, 2012 | Dell Latitude E6510 Laptop Computer (Intel...
Trying to uninstall nero 7 essentials in my laptop, shellmaneger is missing
http://www.nero.com/eng/support-nero7-tools-utilities.html download the tool and follow these directions
  1. Download the file "infotool.zip", save this file to your desktop.
  2. Extract the zipped file on your hard drive using WinZip or WinRAR.
  3. Double-click on the EXE file to start the Nero InfoTool.
  4. The window "Nero InfoTool - Retrieving Information" will open. Please wait until the progress bar has moved completely to the right. The window "Nero InfoTool" will open.
  5. Click the "Save" button (the disk icon at the top). The window "Nero InfoTool - Save/Print" will open.
  6. Please activate all the check boxes (Drive, Disk, Configuration, Software, Hardware, etc.).
  7. Click the "Save" button. The window "Save as" will open.
  8. Name the file and select the "TXT" format as the file type in the dropdown menu.
  9. Select in the "Save in"-dropdown menu the "Desktop" entry.
  10. Click the "Save" button. The Nero InfoTool will be saved on the desktop in the "TXT" format.
  11. Close the two windows "Nero InfoTool - Save/Print" and "Nero InfoTool".
  12. Please send us this file as an e-mail attachment if you contact technical support.
Mar 10, 2011 | Computers & Internet
Download the driver for the webcam
Hi abelw64,
The only way you can get help here is by providing all the needed information. In this case, we will need the specific brand and technical details of your laptop or netbook so that we can check out it's specifications and then suggest an appropriate driver for your system.
If you are running a Windows OS(Operating System) on your laptop, do the following: 1. Go to Start> Run and type in "dxdiag"(WITHOUT the quotes). 2.In the DirectX Diagnostics window, click the "Save all information" tab and select the place to save the Dxdiag.txt file.I suggest you save it to your desktop for easier reference later on. 3.Open the Dxdiag.txt file with notepad(double click it and it will open with the default text editor). 4.Highlight all text in the file(Quick short-cut: CTRL+A key combination), copy it and paste it in this forum.
For detailed system information, repeat the same procedure, but this time, type in the command "msinfo32" and select the save info button.Then copy all it's info to this forum and from there it will be posible to tell the type of webcam that's most likely to be installed on your system.
Do it as soon as possible.
Feb 09, 2011 | Computers & Internet
Error code: 0XEB020B88 when I try to burn music CD's with cyberlinkDVD suite
do the following
Open Notepad (START>>>RUN>>>type in notepad)
Hit OK
Copy the contents of the CODE box, not including the word "code"
Paste it to the empty Notepad file
In Notepad click FILE>>SAVE AS
Change the Save as Type to All Files.
Name the file as Export.bat
CODE regedit /e Export.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}"
Double click on Export.bat, a text file called Export.txt
should produce on your desktop
Copy>>paste back here the contents of Export.txt
Jun 23, 2009 | Computers & Internet
Export Outlook Address Book "Distribution Lists" to cd.
You can save a distribution list as a txt or rtf file which you then can open in MS Word.
1) Click on your contacts
2) double click on the distribution list to "edit/view" it.
3) Go to File -> Save As
4) Save it as a .txt or .rtf (default) file
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 01, 2009 | Computers & Internet
In CD Easy Write Reader
if this problem apperared then how much time spent you by use your cd/dvd rw i give you one suggest if you have cd writer+dvd rom then buy a dvd writer it can works or if you have already a dvd writer then check your region settings for check region settings go to my computer properties and after open properties. Go to Hardware then go to device manager and then go to properties of your drive then select the nation where you live then try it can work i think
Nov 01, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Save number of TXT msg
press more /option on ur right side of ur msg window..from tat save that contact
Aug 07, 2008 | Cell Phones
IPhone POP3 account can't be saved
do a master reset and try again
which version are you using
Jun 26, 2008 | Apple iPhone Smartphone
Dvd reader dosnt work
try to clean up your cd drive...use the cd toolkit cleaner..
if doesnt work..mayb you cd drive broken..
thanks...
Apr 21, 2008 | Acer Aspire 5610 Notebook
Cant see screen on laptop think its videowave???
MS-DOS edit command help edit myfile.txt <press enter>. This would bring up a blank edit screen, as long as the file is saved upon exit this will create the file myfile.txt.
Linux and UNIX xset command help The 'reset' flag forces deactivation of screen saver if it is active. The 'blank' flag sets the preference to blank the video (if the hardware can do so)
Read and follow instructions, good luck, please dont for get to Vote/Thank You
Dec 05, 2007 | Gateway 450SX4 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
