Zanussi Progress 1200 isn't working! I set it on a programme, it starts ok but then 5 minutes in just 'sits' there with the timer no longer counting down. No matter how many times i reset the machine and start again this happens. have checked the filters and they are clear. Please help! Thanks Phil in London pipjones@gmail.com
  • laurastephan Apr 19, 2009
    You've described the exact same scenario we are going through!
  • 183 Answers
SOURCE: long time to dry
Check drain filter on front of machine and check machine is doing full spin. Regards Advisor
Posted on Aug 30, 2007
SOURCE: Frigidaire GLTF2940ES
Is it draining completely?
Posted on Feb 07, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: zanussi progress 1200 WASHER DRYER
This means that the filter is clogged. Get a towel (or two) in our case, and then unscrew the filter. It'll be full of lint.
Posted on Mar 19, 2008
dauphine
  • 207 Answers
SOURCE: just wont work
  1. Turn it off.
  2. Unplug it.
  3. Wait 5 or 10 minutes.
  4. Plug it in.
  5. Turn it on.
Posted on Apr 09, 2008
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Oven timer not working
Make sure you're using right programme. There is a countdown timer that does not affect the oven operation. This is the one with a bell on it. If you want to stop start then use other programmes.
Nov 10, 2013 | Zanussi Ovens
Zanussi progress 1200 won't take softener into
Hi there
Now I am urprised. There must be three dispensers in your Zanussi as in my Candy.
One is for the main wash another for prewash and the third one for
the softner.
Look in the manual.
Kolbrun
Feb 26, 2012 | Zanussi Washing Machines
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
I have a zanussi izzi and it works ok for about a minute and then it stops working and the programme light starts flashing continuosly?? any ideas?? water comes in fine and wash pump works for about a...
Hi
The issue can either be with the unit not draining properly or the timer/electronic board itself has gone bad & should be replaced. First clean the drain hose and the drain pump for any clogs, you can do this by taking off the bottom access panel. After cleaning if still the issue is not resolved then the timer/control board has gone bad and needs to be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 12, 2011 | Zanussi 24 in. IZZI ALU Built-In...
Wjs 1397W. The water goes in OK. The
It was a bad joint on the motor control board. It was well burnt on one of the relay connections. I assume that the machine senses when the drive starts and then stops before changing the relays. Of couirse it only wend in one direction and was waiting for it to go in the opposite one before proceeding.
Jul 09, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Washing programme keeps stalling
Ok, this is a basic control fault within the logic chip set. you will need to replace this faulty control board/timer in this case.the replacement of the control/timer will fix this issue.
Jun 01, 2009 | Electrolux Washing Machines
Just wont work
  1. Turn it off.
  2. Unplug it.
  4. Plug it in.
  5. Turn it on.
Apr 09, 2008 | Washing Machines
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Washing Machines Logo
199 people viewed this question
Top Washing Machines Experts
