Water pump not working in my apartment. the apartment is two years old.no noise when i turn on taps. kitchen unaffected
Hey, this is not an a,c, problem!
Posted on Aug 30, 2008
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
My house is only 2 years old and has begun making a "hammering" noise when I turn on the cold water tap in the bathroom only. The water will actually stop flowing in a moment or two.
If the water actually stops running it might be a problem in the internal balancing valves. Some valves will restrict flows of the other water-supply: If there is slow hot water it throttles the cold water, if there is slow cold water it throttles the hot water. It is meant to stop the screaming in the shower if a toilet for example is flushed and the cold water pressure drops. Some but not all valves can be taken apart and cleaned. Turn off both shut off vavles first!
Oct 18, 2013 | Hansgrohe 06649860 Solaris Single Hole...
Water Ridge Nannini series pull out kitchen faucet rotating at base instead of where it should.
I just fixed our Nannini from Costco. The screens were plugged with plastic filings coming from our water lines. On our faucet there is more than one screen.
The pull out faucet has the basic screen like 99% of the taps out, right on the end. It comes apart by first unscrewing it from the handle and gently (gently) nudging the screen out with a sharp object such as a pairing knife.
Then in the handle was where the problem lay with mine. There was a plastic knob which is recessed in the handle. Leave the hose connected and pull it out until it is stretched or have a helper, then press on that small knob, pull and the whole inside will pull out. There is another filter in there. I was able to take mine apart and clean it, yes it does pop apart but be careful. In assembling mine I just left out the second filter totally.
I guess in hindsite you wouldn't have to actually take the whole handle apart if one has a 90 degree tool to pull out the yellow plastic piece. I used an allen wrench and pulled. Cleaned it with a small needle.
Works better than new!
Nov 24, 2011 | Moen Plumbing
Kitchen mixer tap has gone very hard to turn, it also makes a rubber grinding noise
Sounds like the cartridge has come apart. They are usually free from hardware stores if you take along the old busted one. The faucet comes apart with a few basic tools just make sure you turn off the water to the faucet first and don't go nuts overtightening things when you put it back together.
Apr 22, 2010 | Plumbing
My hot water tap in kitchen makes a loud noise when turned on do i need to replace its about ten years old ?
Somebody has put a rubber tap washer in you need to change it for a fiber washer o.k.?
Mar 09, 2010 | Plumbing
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
I have a 3 year old Sanivite 3 macerator that has stopped pumping. It is used under the kitchen sink for removing water and soft food waste. Yesterday I removed the unit and cleaned the inside which was...
if the unit is properly clean and you have checked the fuse - then i suggest it is the microswitch that needs replacing. these tend to go (break) within 5 years on the sanivite 3 models. If not the swich then it could be the capacitor (try this first - although as the swich is located next to the capacitor you can test this for operation at the same time). if none of this works then its time for a new unit.
Nov 09, 2009 | Saniflo & Saniplus& Macerator Pump
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
