Question about LG Washing Machines
PROBLEM FOR LG MOD.WD-10150FB WASHER - LG Washing Machines
εχω χασι το βιβλιο με τησ συμβολεσ και τησ ενδιξισ οτα εχει βλαβι ,
Posted on Sep 01, 2008
2 Suggested Answers
abhishek33
  • 1239 Answers
SOURCE: Message error:E5 with Washer LG- WD-10150FB
HI
The dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet.
Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy........PLEASE RATE IT
Posted on Nov 28, 2008
Why does my LG washing machine model WD(M) 16115FD show error code dE?
It appears to be a problem with the door? You can go to the following link and try their troubleshooting, hope it helps. http://www.ehow.com/how_7850983_troubleshoot-de-code-lg-washer.html How to Troubleshoot DE Code for an LG Washer eHow
Aug 10, 2014 | LG WD-16115FD Front Load Washer
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Operating instructions for a wd 1049c washer
go to lg's website and put in your model # and you can download the manual
Jun 21, 2009 | LG WD-1041WFH Front Load Washer
LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
HI
Nov 28, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WD-1234FH
You will need to have it checked by a qualified LG technician to see what is the deal with the burning odor.  And the noise is probably the washer not balanced correctly.
Oct 28, 2007 | LG WD-1080FD Front Load Washer
Washing Machines Logo
206 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
