Question about Sony Cyber-Shot DSC-F505 Digital Camera
Flash no more working: error code
The flash of my DSC F505 suddenly stopped working. When I popped out the flash, an error code occured. The handbook says, this error code means, that only Sony can handle with it. I got it repaired at a Sony Service center in Japan. Anybody had the dame problem? Anybody knows about the reasons for that error? -- Joerg
  • rezahmed Dec 28, 2007
    Hi
    I am having the same problem. It flashes an error message.
    Master:
  • 551 Answers
You must have an E:61 or E:91 error. You will need to send it back to Sony but, that is what warranties are all about. I am sure it will be fixed quickly and for free!!
Posted on Sep 11, 2005
How do you replace the flash bulb in sony cyber-shot dsc h10 camera?
You must send the camera in for repair to replace the flashing unit
Jan 23, 2012 | Sony Cyber-shot DSC-H10/B Digital Camera
Memory stick error
Did you format the stick using the camera
if not then try that there seems to be a
problem when formatting with reader
Nov 19, 2007 | Sony Cyber-Shot DSC-F505 Digital Camera
My sony cyber-shot DSC-H10 flash stopped working. The flash pops up like it is going to work, but does not flash. I can take pictures but with noflash. Can you help me?
You flash is in ' Flash forced OFF ' position.Press on the flash control button repeatedly until one of the four modes are selected.
1.Flash Auto - Flashes when there is insufficient light or backlight ( Default Setting )
2.Flash forced on
3.Slow synchro - The shutter speed is slow in a dark place to clearly shoot the background that is out of flash light.
4.Flash forced off - ( Your current mode ).The flash automatically pops up and strobes when using the flash.Close the flash by hand after use.
Jun 03, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera won't flash
Make sure Flash Shoe option is Off in setup menu then check flash light.
Does camera give any blinking error code when flash fails to fire?
Does flash pop up when you press shutter button to take picture in low light?
Let me know to find out possible cause of problem.
Oct 13, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Error message E 91 01
Hi!
The flash fuse on the main board or the flash board is bad. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 06, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Flash on dsc-h3 not working
Hi!
Was it automatically popping up before?
May 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Can Flash be Forced to On
Yes, open up the flash and press the flash button once (the button's on the back of the camera). Hope this helps.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Batteries for Sony DSC-F55 or DSC-F505?
No, those are 'M' series batterys and the F55 and F505 take 'S' series batterys.
Sep 08, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Sony Cyber-Shot DSC-F505 Digital Camera Logo
142 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
