Question about Whirlpool Washing Machines
No drive between motor and gearbox-whirlpool 7100 model
Clutch/brake assembly broken into pieces
Thanks for the reply
B Ryman
Posted on Sep 01, 2008
Washing machine doesnt spin
the problem sounds like the motor to gearbox drive this is two plastic and a rubber unit which is between the motor and gearcase.you need to detach the motor to gain access to this part,should cost you around 20 pounds.
Apr 12, 2010 | Whirlpool LSQ9600L Top Load Washer
What type of drive do I have on my Whirlpool washer model LSB6400LWO . A little confused as to direct drive, belt drive, or transmission?
Your model is a direct drive washer. The output spindle of the drive motor is directly connected to the drum.
Belt drive models use a less powerful motor which is connected to the drum via a drive belt, and the difference in size between the pulley on the drum and the motor acts as a reduction gear to turn the high rpm, low torque motor output into a low rpm, high torque drive to the drum.
Transmission models are a variation of the same idea where a motor is mounted similar to a direct drive model but is indirectly connected to the drum via a reduction gear.
Oct 15, 2009 | Washing Machines
Whirlpool Lsq8243h
unplug washer and lean washer back aganst wall,put something under frount of washer.So you can see under washer .Look and see if the belt are still on the pully or if there streached out (not tight) fix accordingly.
Jan 17, 2009 | Whirlpool LSQ8243H
Kenmore 70 series won't spin
If the washer makes a noise from the front bottom center, when not agitating and not spinning, the motor/gearbox coupling has broken.
closed2a0a669.jpg open7976f3d.jpg It is designed to break, if the load gets enough that the motor may be damaged and is simple (enough) to replace
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models but close enough, some have 2 clips some 3
  • remove screws under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips at rear corners
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Oct 26, 2008 | Kenmore 22422 Top Load Washer
Whirlpool toploader gearbox/clutch removal
Last Night I took the machine apart to find clutch/brake assy ok gearbox was also ok then I noticed shaft coupling was different than new part I had in stock, new part made totally of nylon, old part fitted to machine has steel insert built into nylon. this was not fully located onto motor shaft and the first 1/4" of motor shaft had been stripped back to round ( no flat faces) also inside the steel lined bore of the nylon coupling had been worn to round.I replaced with new coupling of nylon and ensured both nylon parts fully pushed home onto motor shaft and gearbox shaft with any freeplay / gap being allowed in the rubber drive link. This has worked for now but expect trouble in future with worn motor shaft.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper top load washing machine
madindian1
jcf73
It is not the timer, it is a gearbox drive coupling, whirlpoool 285753, parts common to whirlpool roper ge and about a dozen other brands.
  • remove trims from ends of control panel
  • remove scres under trims
pump
pump springclips
body
control panel
Sep 01, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore 90 series agitator problem.
usually it is a gearbox drive coupling, designed to break on exceptional loads
pump
pump springclips
body
control panel
Jul 13, 2008 | Roper RAS8445KQ Top Load Washer
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
