Question about Dirt Devil Vacuums
Dirt devil vacuum cleaner purpose for pets stops working after about 5 minutes of use. This is the second one I have purchased as the same thing happened with the first one. How can I get a refund?
Returned item to store of purchase and received store credit.
Posted on Aug 31, 2008
Dirt devil total pet stopped
Many places that sell vacuum cleaners also repair them. Check out your local dealers.
Feb 04, 2015 | Dirt Devil Vacuums
How do I get a dirt devil purpose for pet instruction manual?
Hello! We have several Purpose for Pets models. I have included the link to the Purpose For Pets Bagless Upright Vacuum model M140000 instruction manual. If this is not the model you have please reach back out to us and include the model number. Hope this helps!
http://bit.ly/1pB8DM1
Jul 10, 2014 | Dirt Devil Vacuums
Themal protector
The pores of the filter might be clogged. To test it turn it on without the filter or dirt cup installed and let it run for a while. If it runs ok you should install a new filter
Jan 25, 2014 | Dirt Devil M0105 Purpose For Pets Hand Vac...
I have the same problem as discussed above. My Hoover Pet Cyclonic upright stops working while using it. The bottom feels hot when this happens. When it first occurred, I emptied the canister and even...
The vacuum is probably getting hot and the thermal sensor in the motor is shutting it off and then allowing it to come back on after it cools down. You mentioned replacing the secondary filters, replace the exhaust filter too.
If replacing all the filters did not solve it you may have a clog or restriction somewhere causing the loss of suction and the overheating.
Mar 09, 2017 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
Twirly thing under the vacuum has stopped spinning
there is a belt that drives the beater brush. flip the unit over, you can remove the bottom cover by removing a couple of screws. to one side of the brush you will see a channel where the belt should be. go to you local walmart, sears or hardware store and in the vaccume section they will have belts, on each bag of belts will be a list of vaccumes that belt fits simply find yours. with the new belt simply lift the beater brush out at the belt channel side and install the belt around motor shaft and brush. then place brush back in place , be suer brush guides are in properly. this should do ya.
Aug 18, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil Purpose for Pets won't ****!!!!
The filters will need cleaning. Make sure the entire cone filter has been gently brushed getting rid of all dust. Also check in the main dust channel where the beater bar is. It may well be clogged and best to check the hose too.
Jan 31, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt devil purpose for pets vacuum quit working
The motor overheats from the filter being clogged underneath the canister or the canister or both are clogged-without the air flow the motor overheats and shuts off as a precautionary measure.By letting the motor cool off it will start again but will turn off shortly if the filters are not properly cleaned.Hope this helps everyone.
Rob
Oct 18, 2008 | Dirt Devil Purpose for Pets Portable...
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
294 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
