Cameras Logo
Posted on Jul 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I slipped in the garage and dropped the camera when it was on==batteries came out and lens of course didn't fully retract. Put batteries back in and the green light comes on and beeps but won't turn on and lens won't either fully retract or come out like usual. Will I need this repaired and if so, where do I need to send it. It's my mom's and I'm kinda disgusted with myself that I seem to have messed it up--I only bought it at Christmas for her. Terry
Anonymous
Level 2:
  • Expert 489 Answers
  • Posted on Jul 25, 2011
Anonymous
Expert
Level 2:
Answers
489
Questions
Helped
139189
Points
960
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
1helpful
The camera will not turn off and the lens is not fully retracted
from your question I understand there may be problems in the lens unit, in some cases totally open the lens unit fully re assemble it again,clean the sensors at side of the barrels, can override this snags.
the below picture is not the same, but similarly you take the cam sect out and reassemble it.
tip
Troubleshoot Non-Retracting Lens Due to Camera Drop
<span>Remove the batteries from your digital camera and leave them out for a few minutes. If you are using rechargeable batteries, make sure the batteries have a full charge before placing them back into the digital camera. It is recommended that you charge the batteries for at least 6 hours. If you are using regular AA or AAA batteries, make sure you are using brand new batteries of the same brand. Turn the camera back on to see if the lens will retract. If that doesn't work, turn the camera back off and try turning it back on while you are pressing the function or OK button.<br />If the batteries were low when the camera was dropped, the lens may not retract properly until the camera is reset. Remove the memory card from your digital camera and install new batteries. Do not put the memory card back into the digital camera and turn the digital camera back on. You will get an error message regarding the memory card, but that is okay. With some digital cameras, leaving the memory card out will trigger a reset within the digital camera.<br /></span><span>If you have an audio/video cable (AV), insert that cable into the digital camera and turn it on. By using an AV cable, the LCD screen will not power on, which means there will be more battery power available to the digital camera. If any dirt got into the digital camera when you dropped it, the extra power may help the camera retract the lens.</span> <span>Place your digital camera on its back on a hard surface. The lens should be pointed towards the ceiling. While pressing the shutter button, turn the digital camera on. The idea behind this concept is that the camera will try to autofocus, which may help seat the lens barrel pins back into their slot.<br /><b><br /></b><br />It is possible that when you dropped your digital camera, dirt, sand particles, etc. may have lodged themselves into the lens barrel. Gently blow around the lens barrel to knock lose any particles. Using a microfiber cloth, wipe off the lens and try to wipe as deep into the lens barrel as you can. You can also try using compressed air and blowing it in the gaps around the lens barrel. Be careful not to blow any of the compressed air onto the lens itself, as the pressure of the air may damage your lens. The idea here is that if there are any particles lodged in the lens barrel by the lens mechanism, you will be able to knock them lose.<br /></span>
on Jun 29, 2011 • Cameras
It keeps saying lens error
Here are some troubleshooting steps for the lens error problem. And here's a video summary of those steps:
Turned camera on gives error message to turn off and back on again . No matter how many times we turn off and on it won't clear the message. Took battery out.put back in. Message still there. Also len
Camera was probably dropped. Motorized autofocus lens was probably damaged when dropped. It doesn't get more of a big deal than this. Depending on age of camera, it may be a ''wipe-out.''
Ps... I'm saying ''probably'' dropped because I didn't see it happen, but this is precisely what happens when they are dropped. It doesn't take much of a ''jolt'' to do the damage, and there is usually never any external damage.
Oct 09, 2012 • Cameras
Hi i have a kodak M753 easyshare and my problem is that it slip of my hand and now the inner lens has only partly retracted and is stuck and won't fully retract. and as soon as i put my camera on , it...
It's broken. It will have to be serviced, and likely need parts replacement. It's up to you, but given the cost of repairs, just in labor, I'd toss it in the recycle pile and get a new one.
1helpful
2answers
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
31helpful
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Lens will not retract
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
