Question about Saeco Magic De Luxe Espresso Machine
Maginix robot cafe machine 4 years old no coffee from nozle or steam pipe - water comes out underneath!
Boiler is leaking, you need to replace it. I did it myself, fairly easy. Spent 135 on boiler Saeco magis deluxe
Posted on Oct 22, 2008
  • 515 Answers
I think you have a leak in a tube or in your boiler.
/Mirran
Posted on Aug 30, 2008
Why no steam.Sunbeam 6910 cafe series. Turned on steam wand this morning and all I heard was a sigh, a feint try to deliver steam but not successful. Very little pump noise / action almost non-existent....
This could be 1 of many issues, usually the Steam pump (black or blue) is corroded and no longer vibrating correctly, the pump could be blocked, the pipe work after pump but before boiler could be blocked, the steam boiler could be blocked, the pipe work after steam boiler but before the steam tap could be blocked, the steam tap could be blocked, and also the milk nozzle could be blocked, if you feel competent to take it apart, it is easy to fix but if not take the machine to local service agent.
Feb 20, 2015 | Sunbeam Cafe EM6910
I can't get water through my Cafe Retro machine
I ruined one Cafe Retro that way, but I managed to fix a second one, here is how: the worst scale tends to build near the exit filter. If poking holes in it with a needle does not work, you need to unscrew that filter.
(1) turn the machine upside down (2) remove the bottom panel by unscrewing the feet (3) remove the central bolt that hold the filter using a special 'snake eyes' 2-pin screwdriver. Since it is hard to find and expensive I made one myself by filing an old screwdriver. I had to use extreme force to loosen the bolt (I enlarged the holes using a small drill, and used a spanner to get more leverage on the screwdriver). (3) once the bolt comes off, remove the dirt that built underneath, and thoroughly clean the filter holes. I used white vinegar and a toothbrush. (4) reassemble the device and run a commercial descaler through it. It's a great machine but poorly designed with respect to scale buildup, now I descale it very often.
Jan 16, 2012 | Ariete Cafe Retro Espresso Machine
Hi, I have a Cafe Chic coffee/expresso/cappiccinno maker that has not been working properly. When I try to make coffee, the water that is suppose to travel through the filter and coffee grains ends up...
obviously you have leaking steam valve, use my recipe for rearing it:
you should take out the knob first, than you try to disassemble the SHAFT of valve from the valve body, in this types(small espresso coffee machines) usually producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal workshop where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine. During assembling valve change 2 o rings and put one fitting 1/4'' to block the shaft coming out.
PS: notice you only polish the SHAFT , don't let them to short the more than 0.5 mm
Mar 03, 2011 | Espressione Cafe Chic 1377
My Sunbeam coffee machine model EM900 twin thermolock cafe series.Was leaking water around group head . Have replaced the grouphead seal but still leaks infact worse My machine is 7yrs old but in good...
I have a Sunbeam twin thermoblock Im having trouble with my steam wand I im not getting much steam out for the milk to warm up try to clean it with a pipe cleaner can you give me an advise how to get it woking
Feb 01, 2011 | Sunbeam Microwave Ovens
Cafe Roma producing more water than steam
you really need to decalc frequently, at least every 2 months. after it goes too long, you will see that problem. have not figured out yet how to fix it.
Jun 18, 2009 | Breville ESP8XL Espresso Machine
Too much water coming out of steam wand
I worked at StarBucks, what we did was put water into a contaner and steam the water, a lot of the time why the steamer doesn'..t work as well is because it is clogged. Another way to do it is to just run your steamer, also go to a coffee store and buy expresso machine cleaner. It could just need a good cleaning.
Apr 16, 2009 | Breville ESP8XL Espresso Machine
Leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Aug 13, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
"water pipe empty" icon will not disappear from display screen 3, cannot brew coffee, first use - second machine to have this problem
I have a Siemens surpresso S40 with the same problem.
Try to fill the tank with hot water. I dont't know why but it solved the problem for me.
Jul 11, 2007 | Bosch Benvenuto B20 Espresso & Coffee...
Saeco Magic De Luxe Espresso Machine Logo
231 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
