Question about Intel Motherboard
Updating BIOS I have checked out the Bios on my computer and it is Intel Corp. 4W4SB0X0.15A.0013.P08 I downloaded a file 7508736 which is an update . 2/15/01 BIOS update 4W4SB0X0.15A.0019.P14 Can anyone tell me how I go about updating the BIOS and would the file I downloaded do the job. Thankyou The BIOS is not fully ACPI complaint, and need to be updated Motherboard Gigabyte BIOS : Phoenix Bois D686 BOIS
  • 778 Answers
Different computers different files
You need two files to do the Job read instructions carefully
1 is for bios the other is the program that install it
Posted on Aug 30, 2008
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
I have 845 mother board of intel. when i boot my computer, it shows f1 for bios entry. when i enter f1, it goes inside bios but after that my keyboard will not work. please help me.
its problem bios not configure properly reset mother board jumpure 1-2 normal 2-3 reset again position 1-2 machin is on press F2 set up bios your choice configure before unpluged your hard drive
Nov 21, 2009 | Intel Motherboard
I need to know how to bios update
That is the right procedure. The next step is to type the path of the BIOS file. Have you tried D:\(bios file name)?
Nov 06, 2009 | Computers & Internet
I want to the bios intel motherboard d845PEBT2 place sent me
First be clear, do you want to update your BIOS & if so then go through this first: To identify your current BIOS version, check the BIOS version string:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Check the Main menu.
  3. The 4-digit number after the '86A' or '86I' is the current BIOS version, as in this example: MQ96510H.86A.1663.2007.0319.1957
  4. Press Escape to exit BIOS Setup.
Important:
  • Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it. You can view all new BIOS fixes in the Release Notes included on the BIOS download page in Download Center.
  • Before initiating a BIOS update, be sure to read and precisely follow the update instructions. You may wish to print the instructions for easy reference.
  • If a BIOS update process is interrupted, your computer may not function properly. We recommend the process be done in an environment with a steady power supply (preferably with UPS).
  • All images in the examples used in the instructions are specific to certain desktop boards and are for illustration purposes only. You need to select the correct BIOS files for your desktop board.
There are up to six methods of updating an Intel® Desktop Board BIOS to the latest version. The number of options made available for any particular board may vary, depending on drive support and BIOS update file size. You only need to use one.
All BIOS update files for Intel® Desktop Boards are available on Intel(link: http://mysearch.intel.com/corporate/default.aspx?culture=en_US&q=d845PEBT2&category=all&adv=0&value=0&searchsubmit.x=30&searchsubmit.y=12).
If simply want to clear the BIOS then either remove the small battery on the MB, wait for a couple of minutes and replace it. Else close to the BIOS chip look for a 3 pin setup on the mother boar with a jumper on two pins Remove the jumper, wait for 10-20 seconds & replace it. That will clear the BIOS.
A word of caution, do not update the BIOS if your PC is working properly. Do it when prompted to,during installing a new software or hardware this message will pop up on the screen.................sodeep
May 15, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Motherboard upgrade
That computer uses a proprietary motherboard. Only that one or one from the same Gateway family will fit, and the power supply from an old PIII will not work with the newer systems. Don't waste your cash.
Cheers
Jan 04, 2009 | Computers & Internet
About bios update
If you have never "flashed" the bios before you will need to go the Intel website where you can enter your Intel motherboard model information. That will lead you to diagrams of your motherboard that shows where any related CMOS jumpers are located and what positions they must be jumpered to accept a flash bios update. You will also be provided with the FIRMWARE file download and instructions. Pay careful attention to the instructions as flashing the BIOS chip can disable your computer if you have the wrong firmware or if the power to the computer is lost while updating.    The model number will be printed on the motherboard itself. It is an easy process if you study the instructions. ~Steve Medley
Nov 15, 2008 | Intel Motherboard
Updating BIOS
Hi aryo,
What I need to know is the name of the motherboard. The bios information is useless without the name of the motherboard & model number.
Apr 24, 2008 | Computers & Internet
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
Even i experienced the same problem after updating BIOS....
There is a simple solution for it..... Just reboot the system and enter to Bios setup by tapping Del key
Press F9 key and set it to default settings... Just save and exit.... USB Ports works fine.....
Mar 17, 2008 | Computers & Internet
Intel Motherboard Logo
567 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
