Question about Nokia 6300 Cellular Phone
Water damaged, No Power
My 6300 damaged with water, i gave alcohol bath, heated with hot air gun, only blue colour led is blinking, no power on, please help me on this
Ur handset 3 time washin in washin machin with ariel.
Posted on Aug 30, 2008
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Garmin nuvi 1350 got wet
Liquid and electronics don't mix. You can cause more damage leaving the power applied to the unit when it is wet. Water is conductive due to the metals found in water. This can short out components and damage them.
Electronics that get wet need to be taken apart right away and washed in a 90% alcohol bath and blown dry with compressed air. The alcohol displaces the water and will dry on its own. The compressed air helps speed up the drying process and blow out any residue in hard to reach places or under parts.
If the unit is allowed to dry without being cleaned, a white residue will form around components and the residue can short out connections.
There are some parts that can't be recovered due to getting wet, like LCD displays, batteries and speakers.
I would suggest taking the unit to a professional to have it looked over. There are some places that won't work on water damaged electronics because even if you can revive them, there is no guarantee they won't die tomorrow and many places will not offer a warranty on water damaged unit.
Mar 25, 2013 | Garmin Nuvi 760 Handheld GPS Receiver
I have a customer who would like a Bosch AE-9.5 tankless water heater installed in the master bathroom. The master bath is located at the far end of the house & they are wasting a great deal of water...
In theory it sounds good, but I don't think it would function properly. Most folks install a low boy 20 or 25 gallon water heater near the master bath and use the home's cold water feed as the supply line. That way, the water for the master bath alone, will always remain hot.Of course this would involve some plumbing modifications.
Of course, the other less expensive solution, would be to insulate the hot water pipe(s) feeding the master bath, from the existing water heater. That way, there would be no heat loss in the pipe(s) so the water in the pipe would remain warm to hot all the time.
Either of the above solutions should heat things up for your customer.
Mar 07, 2011 | Heating & Cooling
The "clean" led flashes and
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | Kenmore Dishwashers
I was playing my playstation 3 and all of a sudden it shut down and began to blink a red light. It did this a second time. What is wrong with it? Please help?
Your problem is yellow light of death which can be fixxed with heat gun hot air gun and the right person or your power supply internally is going out.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
My nokia 6300 is water damage. blue lights are blink only and pw ic is heat up....what can i do sir
your cellphone short circuited. that means that your board is damaged when water goes in. ICs tend to short circuit and that could be damaging to your phone. i advise you to have that fixed at a nokia center. and i hope that they can have that fixed.
Nov 02, 2010 | Nokia 6300 Cellular Phone
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Red light keeps blinking
You need a screwdriver, a heat gun, arctic silver compound, lots of patience.
Dismantle your ps3 down to the motherboard. Clean off the compound on the Graphics chips with isopropyl alcohol. Set your heat gun to around 700*F. Apply hot air to each of the Graphics chips, 1" away, in a swirling motion for 15-17 seconds each on one side. Let cool down for 20min. DO NOT MOVE THE BOARD. Repeat for the other side. Let cool down for 20min. DO NOT MOVE THE BOARD. Apply new compound to the graphics chips with Arctic Silver. Put the PS3 back together and it should work. It worked for me!
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
Ps3 comes on light changes to amber then blinking red wont stay on longer than 3 seconds Same problem, it tries to start, makes a litle wizing noise and stops, the red light blinks until you close it at...
May 26, 2009 | Sony Playstation 3 (PS3) Console
Nokia 6300 Cellular Phone Logo
129 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
