Question about HP DeskJet 1280 InkJet Printer
Error in A3 print
Hi
i want to print A3 size with hp 1280 but it prints in A4 size .I set the setting but it doesn't work please advice me .
thanks
  • 4 more comments
  • dansimion81 Sep 03, 2008
    I use Autocad 2008 and a Xerox 5225 Workcenter. I need to print on A3 paper. It actually prints on A3 paper but the drawing is a4 size (tiny in one corner of the a3 paper). Any ideas? 10x
  • manoj28184 Sep 12, 2008
    whan i give network throug A3 print i not get the prin.that time i have got the unexpected paper size eaarer.pls help me
  • Anonymous Nov 06, 2008
  • http Nov 11, 2008
    HELLO
    IM ALSO HAVING THE SAME PROBLEM . I COULDNT FINE THE LINK FOR 1220 CAN U SEND ME THE LINK PLZZ
  • nitinrokde Jan 03, 2009
    i also have the same problem, with the error massage "unexpected paper size" even in A4 size in Landscap.
    pls let me the proper solution, it is the problem with this model?
  • rajendra_jku May 09, 2009
    i have the same problem not getting print from the Autocad 2008 A3 sheet. it working in A4 sheet.
I had the same problem. Didn't find the answer. I removed the HP 1280 driver and installed HP 1220 Driver. It worked. It prints all the sizes perfectly. What is in name if we get the prints on A3 size. whether it is HP 1280 or HP 1220 :)
Ajay
Posted on Sep 15, 2008
Have you tried changing the default paper size from the control panel?
Control Panel > Printer and Faxes > Right Click "Your Deskjet 1280" then Properties > Printer Preferences > "Change Paper Size
Posted on Aug 31, 2008
Hp 1280 vista software
You might have to Physically goto which ever program you are printing from and goto File and then Printer Options or Page Options and select the A3 Print that you want. If you wan to set the printer to A3 for ever you too can goto START, Control Pannel. Then Find and open PRINTERS , then right click on your printed listed there and goto PROPERTIES. From there you can navigate the tabs on top until you find the paper section of the printer and set the paper to whichever choice you want in this case A3... If you are still not able to get it from there try to download the latest software update form the Printer site itself. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
May 06, 2009 | HP DeskJet 1280 InkJet Printer
I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Mar 07, 2009 | HP DeskJet 1280 InkJet Printer
Cannot print A3 on HP 1280
go to custom then set your paper size 297x420mm
Aug 13, 2008 | HP DeskJet 1280 InkJet Printer
Printing problem
there is one setting on u r printer properities ..please check it if u can not solve problem please download team viewer using below link install on u r pc & give me call on Gtalk my mail id is Kordesandip@gmail.com .....
useing teamviewer i can remotely acess u r pc & check it settings of printer ..
link for Team viewer
http://www.teamviewer.com/download/index.aspx
Thanks & regard
Sandipk
9970066991
Jun 17, 2008 | HP DeskJet 1280 InkJet Printer
Printer problem
From the Printers & Faxes window, check in the i9950 Printing Preferences, Page Setup tab, for the following settings:
Page Size and Printer Paper Size are both set for the same size (both A4 or both A3).
Printing Type is set for Normal-size Printing
The graphic on the left should now show A4 (or A3) and Normal-size Printing in the legend.
Once that is set, verify from the application you're printing from that these settings are not being changed by the application (Preferences button in the print dialog box).
Jun 16, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Printer Problem in HP-1280 Printer
go to printer folder , select properties and go to paper /quality , browse to A3, select, apply, OK
check print preview before sending your document
May 01, 2008 | HP DeskJet 1280 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
1,922 people viewed this question
Seeker5211
Seeker5211
