WEB CAM Fault
When ever i try to put the cam on it restarts my PC. Currently i am using XP, even tried to reinstall the software but to no avail. Please Advise
    President:
  • 8,637 Answers
Normal 0 There are a number of things that can cause the camera to freeze up the computer.
First I’d check to see how much memory is installed in the computer. It takes additional memory to operate the camera.
Hope this helps. Bud
Posted on Feb 03, 2009
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
Web cam not working
Hi there, please follow the steps.
Hi there follow the instruction below.
1**. Double click my computer then double click USB Video Device.
You can see your self then. If the USB Video Device not showing
there then you have to install the cam first.
2. Power On the laptop/PC & after ready your OS for work just put
your Webcam driver disk in DVD/CD RW/ROM. when its open, that
time just select webcam driver and install it as per your operating
system(Vista or XP). So do it, and after finish installation ,restart the
laptop. Your will see your cam is ready for use.
Then follow again the first instruction.**
3. When you confirm after viewing your self in cam , then stop it. Now login on messenger & click to connect the cam from messenger. If any doubt then then ask me a again. Thanks & waiting for your feed back.
Thanks & waiting for your feedback.
Jun 08, 2010 | Acer Aspire One PC Notebook
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Web Cam Not functioning properly
You may uninstall the web cam driver from the Device Manager then restart the Computer. After restarting the Computer, please reinstall the web cam driver. You may locate the Web cam driver under the Imaging Devices category in the Device Manager. If the issue persists then you may perform System Restore to restore the system files to the time when the web cam worked normally.
Jun 23, 2009 | Computers & Internet
Webcam is not working
Is this the Acer Aspire One 8.9 -inch Netbook (1.6 GHz Intel Atom N270 Processor, 1 GB RAM, 160 GB Hard Drive, XP Home, 6 Cell Battery) Black
It's due to the software that starts with your PC. . .
Try
  1. Start Menu
  2. Run
  3. type MSCONFIG
  4. select Start-up Tab
  5. and disable the Web Cam Software
  6. Select Apply then Ok
  7. * Note it will ask to restart* Restart PC
  8. then open Messenger again and try web cam
Dec 23, 2008 | Computers & Internet
Webcam driver stops working during regular PC operation.
If the Web cam was Generic, or even Brand name, and it came with a Drivers disc (this would mean that it is not plug and play), try completely uninstalling the Driver software for the web cam. After the uninstall has finished, reinstall the drivers, taking extra care to follow ALL on screen instructions to the T. If at some point there were other web cams, and the drivers that belonged to those cams installed on the computer, be sure to fully uninstall all of them. Only use the cam and the drivers that you are attempting to install. After all of that, the cam should work just fine.
If for some reason the cam does not work after reinstalling the drivers, try a different brand of web cam. The computer that the drivers are attempting to operate on may not be adequate to support those drivers. If that's the case, try a generic, cheaper web cam as I said.
Also: While powering up the cam, don't run anything unnecessary.
Hope this helps.
Nov 22, 2008 | Computers & Internet
Web cam problem
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Thanks
Mar 11, 2008 | Acer Aspire 5630 Notebook
My cam
Thanks
Mar 08, 2008 | Acer Aspire 5610-4648 Notebook
Acer orbi cam not working
Thanks
Mar 07, 2008 | Acer TravelMate 3260-4874 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
