Question about HP Pavilion dv6000z Notebook
Flickering screen on hp6335 pavilion notebook, not sure what to do?
    Brigadier General:
  • 6,966 Answers
Flickering screen could be indicative of a loose connection or a cold solder. Most likely, it would be in the inverter and/or CCF (cold cathode florescent) lamps. This is a relatively easy repair by re-soldering. It is perhaps more of a task to open the panel lid/cover of the LCD display.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
Monitor screen rolls and flickers periodically for several seconds to a few minutes
Check if the System is installing updates or any other hidden program this might lead to screen flickering
Dec 17, 2013 | HP Pavilion dv9820US PC Notebook
Screen flicker
Check the ram first then check the screen cable
Nov 20, 2013 | HP Pavilion dv9933cl PC Notebook
My screen is flickering on my HP pavilion dv5-1015nr. Is it worth it to take it apart and see if it is a loose cable connecting the screen?
Yes. When your screen starts to flicker, you need to loosen it to check for a loosened cable connecting to the screen. You can as well assess the module for any damage, if the module is bad, then you replace it.
If your laptop is still under warranty, then you need to take it back to the dealer that supplied it to you for their technical support. So they will either fix it for you or replace it. Be sure to have your warranty card or letter when taking it back to the dealer, if not they will not attend to you.
It is mainly caused when the laptop is dropped hard or hit a hard object. So be sure you have it carefully handled.
Take care and good luck.
Dec 17, 2010 | HP Pavilion dv5-1015nr Notebook / Intel...
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ... › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
The module of the laptop is what makes the screen to flicker.
The module serves like a fle in a laptop.
Take care
Jul 16, 2010 | HP Pavilion dv6000z Notebook
Hp pavilion dv5, flickering screen problem mostly when 26" external monitor is connected, Using Windows Vista 32bit
First restart the computer and tap f10 key on keyboard to enter bios, and check wethere the screen flickers or not you can even try to tilt the screen and check as the drivers doesnt works in bios screen ... if the screen flickers then it is a hardware issue .. if it doesnt then log on to safe mode with networking by pressing f8 as the notebook restarts and then go to device manager by typeing device at the start search and the uninstall the video driver and then reinstall it from support and drivers ..issue will be resolved if not then do a bios update from, support and drivers.
Apr 29, 2010 | HP Pavilion DV5-1000US Laptop
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Dec 19, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv2000 Screen Flicker
Please replace the screen for optimal performance.
Do rate this.
Feb 25, 2009 | HP Pavilion dv6000z Notebook
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Screen flickers
It is either the inverter board or the backlight. There are no fixes, only replacement.
Nov 10, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion dv6000z Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
